Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1525 Discussions
can't connect to devcloud
ASAF2
hello!
I am using devcloud for about 2 months, and for the last few days I am not able to connect to devcloud.
after ssh devcloud it seems I succeed to connect to the cloud :
but after few minutes  trying to connect i get the following message:
Connection to devcloud closed.
can you help me solve this?
thanks
Asaf
AlekhyaV_Intel
Thank you for posting in Intel Communities. We would like to know which devcloud you're using. Please let us know whether you're using "DevCloud for oneAPI" or "DevCloud for Edge".
Also, we would like to check whether your account has expired or not. Could you please login to this page(https://devcloud.intel.com/oneapi/get_started/) to find your devcloud account expiration date to the rightmost corner of the page and let us know?
However we will contact you through private message/private mail to get your devcloud User-ID
Alekhya
AlekhyaV_Intel
Thank you for responding to our private message. We have made a note of it. Could you please let us know which devcloud you're using? Is it DevCloud for oneAPI or Devcloud for Edge?
Alekhya
ASAF2
Thank you for your response!
I am using DevCloud for oneAPI
AlekhyaV_Intel
Thank you for letting us know. Could you please share a screenshot of the error you're getting. And also please try to access Jupyter notebook(https://jupyter.oneapi.devcloud.intel.com/) and let us know if you're able to access or not.
Alekhya
ASAF2
Hi Alekhya,
I am able to access to Jupyter notebook.
attached print screen of the exit error.
thank you very much for your help
AlekhyaV_Intel
Could you please share your DevCloud config file?
Alekhya
AlekhyaV_Intel
Hi Asaf,
We have verified your config file that you sent through private message. We couldn't reproduce your issue. But we have a suggestion for you that might resolve your issue. Please find it below:
If on MAC change proxy as shown below
Host devcloud
User uxxxxx
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-58xxx.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
Hostname devcloud.intel.com
LocalForward 4022 c009:22
ProxyCommand /usr/bin/nc -X 5 -x PROXY_HOSTNAME:PORT %h %p
Please make the above changes and let us know if the issue still persists.
Alekhya
AlekhyaV_Intel
Does your issue still persist? Could you please give us an update regarding this issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
