Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
cannot Connect from Linux(SSH)
Xiaojun_H_Intel
I followed this guide to connect devcloud from linux but failed.
The error log is,
OpenSSH_7.6p1 Ubuntu-4ubuntu0.3, OpenSSL 1.0.2n  7 Dec 2017
debug1: Reading configuration data /home/intel/.ssh/config
debug1: /home/intel/.ssh/config line 4: Applying options for *
debug1: /home/intel/.ssh/config line 7: Applying options for devcloud
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: Applying options for *
debug1: Executing proxy command: exec /bin/nc -x proxy-us.intel.com:1080 devcloud 22
debug1: permanently_drop_suid: 1000
debug1: key_load_public: No such file or directory
debug1: identity file /home/intel/.ssh/devcloud-access-key-34105.txt type -1
debug1: identity file /home/intel/.ssh/devcloud-access-key-34105.txt-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
ssh_exchange_identification: Connection closed by remote host
any idea about this?
Rohith_K_Intel
Please make sure that the correct path and name of the key is provided in the config file.
ie, if the name is "devcloud-access-key-34105.txt" and it is in the  "~/.ssh/" folder,
the config file contains:
IdentityFile ~/.ssh/devcloud-access-key-34105.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-34105.txt guest@devcloud.intel.com
Manually verify whether the key file is present in the ~/.ssh folder and set correct permissions as below:
chmod 600 ~/.ssh/devcloud-access-key-34105.txt
chmod 600 ~/.ssh/config
If issue persists, download the correct key once again using chrome browser and try with the same.
Xiaojun_H_Intel
Thanks. But this issue still exists after applying the steps you suggested. I was trying to connect  DevCloud from Intel China. Should I set a certain ssh proxy, or any ssh configuration missing in my environment?
More info:
I tried to connect DevCloud with external network not Intel's, it can connect. It looks like a ssh proxy issue. Is it possible for DevCloud team provide an available ssh proxy and the relevant configuration method? Otherwise, we cannot access it from Intel China. Thanks.
ChithraJ_Intel
Since you are connecting from Intel network, you need to set some proxies in the config file.
Could you please create a config file (~/.ssh/config) with the following lines.
    Host devcloud_proxy
    User u34105
    HostName c009
    Port 4036
    IdentityFile "/home/intel/.ssh/devcloud-access-key-34105.txt"
    ProxyCommand ssh -T devcloud-socks-proxy
    Host devcloud-socks-proxy
    User guest
    Hostname cluster.colfaxresearch.com
    LocalForward 4036 colfaxserver:22
    ProxyCommand nc -x proxy-us.intel.com %h %p
Hope it helps. If you face still face any issues, please feel free to reach out to us.
Xiaojun_H_Intel
After running "ssh devcloud_proxy -vvv", error shows as follows this time:
debug1: /home/intel/.ssh/config line 6: Applying options for devcloud_proxy
debug1: Executing proxy command: exec ssh -T devcloud-socks-proxy
debug1: identity file /home/intel/.ssh/id_rsa type -1
debug1: identity file /home/intel/.ssh/id_rsa-cert type -1
The content in config file:
#Host devcloud
#    User u34105
#    IdentityFile ~/.ssh/devcloud-access-key-34105.txt
#    ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-34105.txt guest@devcloud.intel.com
Host devcloud_proxy
    User u34105
    HostName c009
    Port 4036
    User guest
ChithraJ_Intel
Could you please try removing the debug mode from the ssh command as below
ssh devcloud_proxy
Xiaojun_H_Intel
If I removing the debug mode, the command returned immediately with the following log:
Rohith_K_Intel
Could you please check whether you are able to connect to DevCloud via Jupyter Notebook from the internal network?
Xiaojun_H_Intel
Yes, I was able to connect devcloud via Jupyter notebook. However, it is not convenient to access files and execute shell command in that way.
Rohith_K_Intel
Please try by changing the config file as below (replace the user id with yours):
Host devcloud
User u301XX
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-301XX.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
LocalForward 4022 c009:22
ProxyCommand nc -x proxy-us.intel.com:1080 %h %p
#ProxyCommand nc -x child-prc.intel.com:913 %h %p
Xiaojun_H_Intel
It seems the same issue.
MENGKEAN_K_Intel
I use the following config file (modified to your user id) , it works for me.
Host devcloud
    User u34105
    HostName localhost
    User guest
    Hostname devcloud.intel.com
Xiaojun_H_Intel
It still doesn't work. Is there any special configuration need to be done first?
Rohith_K_Intel
Try with below config:
Host devcloud
User u34105
Port 4022
User guest
ProxyCommand nc -x child-prc.intel.com:1080 %h %p
Xiaojun_H_Intel
Yes, it works finally. Thank you all for your help these days!
Rohith_K_Intel
Happy to know that it worked!
Closing this thread. Feel free to raise a new thread in case you face any further issues.
