I cannot access devcloud. It's been a few months since I used it so I deleted the old .ssh/config setup and reran the setup script. See below.
rscohn1@rscohn1-mobl1:~$ bash ~/windows/Downloads/setup-devcloud-access-50659.txt
The /home/rscohn1/.ssh directory for SSH client configuration already exists.
Appending SSH connection configuration to /home/rscohn1/.ssh/config
Creating the private SSH key /home/rscohn1/.ssh/devcloud-access-key-50659.txt
Important: this file is your access key, keep it safe like you would a password.
Done! Now you can access Intel DevCloud by running ssh devcloud or, if you are behind a proxy, ssh devcloud.proxy
rscohn1@rscohn1-mobl1:~$ ssh -vvv devcloud
OpenSSH_8.2p1 Ubuntu-4ubuntu0.4, OpenSSL 1.1.1f 31 Mar 2020
debug1: Reading configuration data /home/rscohn1/.ssh/config
debug1: /home/rscohn1/.ssh/config line 1: Applying options for *
debug1: /home/rscohn1/.ssh/config line 160: Applying options for devcloud
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 19: include /etc/ssh/ssh_config.d/*.conf matched no files
debug1: /etc/ssh/ssh_config line 21: Applying options for *
debug1: Executing proxy command: exec ssh -T -i ~/.ssh/devcloud-access-key-50659.txt guest@ssh.devcloud.intel.com
debug1: identity file /home/rscohn1/.ssh/devcloud-access-key-50659.txt type -1
debug1: identity file /home/rscohn1/.ssh/devcloud-access-key-50659.txt-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.2p1 Ubuntu-4ubuntu0.4
Received disconnect from 12.229.61.118 port 22:2: Too many authentication failures
Disconnected from 12.229.61.118 port 22
kex_exchange_identification: Connection closed by remote host
Killing and restarting my ssh agent fixed the problem. Please close the issue. Thanks.
Robert
Thanks for posting in Intel forum.
Could you download the "setup-devcloud-access-xxxxx.txt" file again and try connecting devcloud?
Your issue might be due to corrupted ssh key. Also make sure that the path to config is correct.
Janani Chandran
Robert
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
