Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
cant access VPN , The password showed invalid
Shreeya1
I am not able to access via VPN and it shows sometime the password is invalid as Ihave been tried in several times.
Can you please help me.
Thank you!
JaideepK_Intel
Can you please share the below details:
  • Which devcloud are you using ? (OneApi/Edge/FPGA)
  • Without VPN were you able to connect to the devcloud ?
  • If possible can you share your config file ? (Please hide your devcloud id while sharing config file)
Can you please run the below command and attach the log files:
ssh -vvv devcloud
Jaideep
JaideepK_Intel
Can you please share the details mentioned above.
Jaideep
Shreeya12
Hi ,
Yes, I have been tried to change the password and tried in 3 times to change the password.
Now it has worked successfully.
Sorry for not replaying.
Thank You for your sincere support!
Shreeya
JaideepK_Intel
Thank you for the confirmation. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
josed19x
I try to change my VPN's password because it expired. The system only tell me it needs 8 characters, but it doesn't explain me witch kind of characters I need to include in the new password.
