Dear Support Team,
I am having a runtime error when running a SYCL code on GPUs queue.
The code is attached below. It compiled and run correctly on login node.
I was able to run the code without issues last week.
Steps to reproduce the problem (s012-n0001)
qsub -I -l nodes=iris_xe_max:quad_gpu:ppn=2
dpcpp -O2 matmul.cpp -o matmul.x
The error message is for level-zero backend is:
SYCL_PI_TRACE=1 ./matmul.x
SYCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_opencl.so
SYCL_PI_TRACE[basic]: Plugin found and successfully loaded: libpi_level_zero.so
SYCL_PI_TRACE[all]: Selected device ->
SYCL_PI_TRACE[all]: platform: Intel(R) Level-Zero
SYCL_PI_TRACE[all]: device: Intel(R) Iris(R) Xe MAX Graphics [0x4905]
terminate called after throwing an instance of 'cl::sycl::compile_program_error'
what(): The program was built for 1 devices
Build program log for 'Intel(R) Iris(R) Xe MAX Graphics [0x4905]':
Internal linker error -11 (CL_BUILD_PROGRAM_FAILURE)
Aborted
The error message is for opencl backend is:
SYCL_PI_TRACE=1 SYCL_DEVICE_FILTER=opencl:gpu ./matmul.x
SYCL_PI_TRACE[all]: platform: Intel(R) OpenCL HD Graphics
Internal linker error -42 (CL_INVALID_BINARY)
Aborted
Perhaps there is some recent changes that I am not aware of.
You advices are much appreciated.
Regards.
Glad to know that your issue is resolved. Thanks for sharing the solution with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
Thanks for posting in Intel forums.
We are looking into this. We will get back to you soon.
Janani Chandran
Dear Janani,
Thanks for looking into the problem.
I would like to give some updates on the problem.
I think the error is probable associated with calling std::rand() on the GPU, as showing in the code snippet below:
SYCL_EXTERNAL int rand();
queue.submit([&](auto &handle) {
handle.parallel_for(range(m, p), [=](auto index) {
int i = index[0];
int j = index[1];
A_USM[i*p+j] = (float)rand()/(float)RAND_MAX;
queue.wait();
(Per SYCL standard, I had to declare rand() with SYCL_EXTERNAL attribute)
The problem is solved by initialization all the matrix on the host.
random_matrix<float>(A_USM, m, p);
If you have other comments, please let me know. Otherwise, I think the issue could be closed.
Once again, thanks for your time.
Regards.
Janani Chandran
