Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
client_loop: send disconnect: Connection reset by peer
Tchouanga__Franck
please how does this error affect the job I have submitted before it happened. Does it continue or restart please help
client_loop: send disconnect: Broken pipe
AthiraM_Intel
You can use nohup command to run the job. Nohup is a command in Linux systems that keep processes running even after exiting the shell or terminal.
Please use the below command to run your job file.
nohup qsub job &
You can view the output of your script in the nohup.out file, which is created while running the job.
Hope this helps. If you face any issues please let us know.
Tchouanga__Franck
please can I have an overview on how to apply it
should I just type nohup job&
Tchouanga__Franck
hope its ok if I run it like this
nohup python PythonDemo.py | qsub
Tchouanga__Franck
I am getting this hope its ok
u38804@login-2:~$ nohup echo python PythonDemo.py | qsub &
[1] 7204
u38804@login-2:~$ nohup: ignoring input and redirecting stderr to stdout
567652.v-qsvr-1.aidevcloud
[1]+  Done                    nohup echo python PythonDemo.py | qsub
u38804@login-2:~$
u38804@login-2:~$ qstat
AthiraM_Intel
Hi ,
Please follow the below steps to run a job file:
Step 1. Create job file
vi job
Step 2.  Inside the file please add
#PBS -l walltime=24:00:00
python sample.py
Please note, change the <sample.py > to your file name.
Step 3. Save the file
Press [Esc] to shift to the command mode and press :wq! and hit [Enter] to save the file.
Step 4. Run the job
nohup qsub job &
Hope this helps.If you face any issue, please let us know.
AthiraM_Intel
Could you please confirm whether the solution provided was helpful?
AthiraM_Intel
Hope the solution provided was helpful. We are closing this thread. Please feel free to open a new thread if you have further queries.
