Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
command GETQUOTA does not work
STyur
Since this sunday, command getquota does not work for me.
It send POST request to http://login-1:898/ and wait answer forever.
Please check.
JEYANTHKRI_N_Intel
Thanks for reaching out to us,
We will contact our DevCloud Admin team and let you know.
JEYANTHKRI_N_Intel
Could you please let us know whether the issue is resolved now?
STyur
Unfortunately, not completely.
It does not work on login node:
Last login: Thu Dec 26 21:26:30 2019 from 10.9.0.249
u32955@login-1:~$ getquota
curl: (7) Failed to connect to login-1 port 898: Connection refused
u32955@login-1:~$ ifconfig
ens5: flags=4163<UP,BROADCAST,RUNNING,MULTICAST>  mtu 1500
        inet 10.9.0.1  netmask 255.255.128.0  broadcast 10.9.127.255
        inet6 fe80::5054:ff:fe09:1  prefixlen 64  scopeid 0x20<link>
        ether 52:54:00:09:00:01  txqueuelen 1000  (Ethernet)
        RX packets 555927952  bytes 2866226633646 (2.8 TB)
        RX errors 0  dropped 0  overruns 0  frame 0
        TX packets 5303458484  bytes 7894273512823 (7.8 TB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
but it works from interactive session:
# Resources:           neednodes=1:fpga_compile:ppn=2,nodes=1:fpga_compile:ppn=2,walltime=06:00:00
u32955@s001-n147:~/Projects/compile_tf_graph$ getquota
86.98 GB out of 200.00 GB (43.49%) used
ywang273
Hello, I have the same problem. Have you solved it?
JEYANTHKRI_N_Intel
The issue is resolved now. Could you please confirm the same from your end.
STyur
Yes! I confirm that the problem is resolved!
88.35 GB out of 200.00 GB (44.17%) used
u32955@login-1:~$
u32955@s001-n147:~$ getquota
u32955@s001-n147:~$
JEYANTHKRI_N_Intel
Thanks for the confirmation,we are closing the case.
