I am trying to run oneAPI on cloud and I followed the documentation(the link below) that explains how to connect to servers through ssh using visual studio for oneapi development. In fact it assumes that I know the ip address or name of the server that I want to connect. How do I get a server that I could use for running oneAPI on cloud?
https://devcloud.intel.com/oneapi/connect/connect-with-vscode/
Any help is greatly appreciated!
Hi ,
Thank you for posting in Intel DevCloud Forum.
We hope that you have done all the configuration steps given in the following link to connect to DevCloud :
Also,you need to setup SSH config and the detailed steps are given in the following documentation :
https://devcloud.intel.com/oneapi/connect/connect-with-ssh-linux-macos/
You can find the host name in the configuration file ./.ssh/config
For example , if this is the config file details :
Host devcloud
User uxxxxx
IdentityFile ~/.ssh/devcloud-access-key-xxxxx.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-xxxxx.txt guest@devcloud.intel.com
Then do :
ssh devcloud
(the name corresponding to the Host is devcloud in first line )
Hope this will be helpful
Raeesa
Is your issue resolved? Please let us know if you were able to connect to DevCloud successfully.
Thank you
We haven't heard back from you for a while. We are discontinuing monitoring this query. Please raise a new thread if you have any further queries .
Thank you ,
Raeesa
