Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1661 Discussions
devcloud for oneapi is not accessable
JyothisV_Intel
Good day to you.
We're happy to hear that the connectivity issue is resolved.
> Is there any free instance of dev cloud for Intel employee to develop or test?
Intel® DevCloud for oneAPI offers free access to Intel® oneAPI toolkits and components along with the latest Intel® hardware.
The available hardware details are provided in the "Homepage": https://devcloud.intel.com/oneapi/home/
The steps to access these resources is explained in the "Documentation" page: https://devcloud.intel.com/oneapi/documentation/
Intel® DevCloud for oneAPI offers both SSH and VSCode based connectivity options which is also explained in the documentation page above. Additionally, an easy to launch Jupyter Lab environment is also available which can be accessed from "Connect with JupyterLab" section in the bottom of the "Get Started" page: https://devcloud.intel.com/oneapi/get_started/ as shown below:
If this resolves your query, kindly mark this as a solution as it will help others facing a similar issue. If you need more assistance with any Intel products or services, do get back to us.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
The correct link to access Intel DevCloud for oneAPI is the one which you used: https://devcloud.intel.com/oneapi/
Can you provide us with some more information along with a screenshot of the exact issue you are facing so that we can assist you better.
Additionally, it would be helpful if you could try accessing the link https://devcloud.intel.com/oneapi/ after following all/any of the below suggestions:
  • Clear browser cookies and cache
  • Use an incognito window or a different browser to access the above link
  • If you are using any VPN/Proxy services, kindly try disabling the same to access the link
If you are an Intel employee connected to Intel VPN facing issues logging in, kindly try using the "Employee Sign In" option as shown below:
Jyothis V James
Xiaojun_H_Intel
Yes, I can access the website after disabling VPN. Thanks for your suggestion. I have one more question. Is there any free instance of dev cloud for Intel employee to develop or test?
JyothisV_Intel
Good day to you.
Thanks and Regards,
Jyothis V James
JyothisV_Intel
Good day to you.
Thanks for accepting our solution.
Since your initial query is marked as resolved, Intel will no longer monitor this thread.
If you need any assistance with Intel® products and services, kindly post a new question.
Jyothis V James
