Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
disable hyperthreading devcloud
dreamalone
Is there any way to run the parallel job without hyperthreading on?
because of hyperthreading my program is taking too much time to finish
#PBS -l nodes=2:ppn=12,walltime=24:00:00
But when I use
#PBS -l nodes=1:ppn=12,walltime=24:00:00
my job starts within a sec.
JananiC_Intel
Thanks for posting in Intel forums.
Are you using mpi in your code? Could you share the reproducer to check from our end?
Janani Chandran
dreamalone
@JananiC_Intel  Apology for the late response.
Yes I am using MPI in the code.
The code is Quantum Espresso (https://www.quantum-espresso.org/)
if you require input files then will share. But i believe you can get all the information on the given site.
Please have a look.
JananiC_Intel
Thanks for the update.
We will check on this internally and let you know.
Janani Chandran
dreamalone
dreamalone
@JananiC_Intel
My problem is resolved.
My job is taking a lot of time because of inter-node MPI communication.
Not because of Hyperthreading.
JananiC_Intel
Glad to know that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored
Janani Chandran
