Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1797 Discussions
error while loading shared libraries: libsycl.so.5
Siyoung
oneAPI version 2023.2.0
(gst-plugin-scanner:53): GStreamer-WARNING **: 07:08:21.945: Failed to load plugin '/opt/intel/openvino/data_processing/dl_streamer/lib/libgpurenderer.so': libsycl.so.5: cannot open shared object file: No such file or directory
(gst-plugin-scanner:53): GStreamer-WARNING **: 07:08:21.948: Failed to load plugin '/opt/intel/openvino/data_processing/dl_streamer/lib/libvasot_gpu.so': libsycl.so.5: cannot open shared object file: No such file or directory
These problems are occured in Docker Container in EII System.
How can I solve this problems?
Siyoung
I installed 4.0.0 and tried to use basler camera.
in ia_video_ingestion log
logs ia_video_ingestionlogs ia_video_ingestionI think the error about '.so's are disappered
but I wondering It stream really so how can I check  stream result?
JesusE_Intel
Hi Siyoung,
Thanks for reaching out, could you please share what version of Edge Insights for Industrial you are using? Are you seeing the error during installation? If so, please share all the files/content in the following directory: /var/log/esb-cli/Edge_Insights_for_Industrial_<version>
Could you check if any docker containers are rebooting with docker ps? If any are rebooting, please provide any error message seen with docker logs [container_name] for example docker logs ia_factoryctrl_app.
Jesus
Siyoung
EII Version : 3.0.1
during using Basler Camera for Video Ingection.
docker logs ia_factoryctrl_app docker logs ia_factoryctrl_appdocker logs ia_factoryctrl_app
docker logs ia_video_ingectiondocker logs ia_video_ingectiondocker logs ia_video_ingection
JesusE_Intel
Hi Siyoung,
Thanks for providing the additional information, is it possible to upgrade to Edge Insights for industrial 4.0.0? The previous release is no longer available on our website.
Additionally, could you provide the changes made to the video ingestion to ingest the Basler Camera? I see you are using bayerbggr pixel format. Would you mind testing a different format to see if the error is the same?
"type": "gstreamer",
"pipeline": "gencamsrc serial=<DEVICE_SERIAL_NUMBER> pixel-format=bayerrggb ! bayer2rgb ! videoconvert ! video/x-raw,format=BGR ! appsink"
Ref: https://eiidocs.intel.com/3.0.1/IEdgeInsights/VideoIngestion/docs/basler_doc.html
Jesus
Siyoung
with
--> result
pipeline changepipeline change
Siyoung
then, How Can I upgrade to 4.0.0?
JesusE_Intel
Hi Siyoung,
You can download the latest Intel Edge Insights for Industrial from Edge Software Hub. Here is the page: https://edgesoftware.intel.com/industrialinsights/
Jesus
Siyoung
JesusE_Intel
Hi Siyoung,
If you are using the default app without any other changes other than the camera stream. You should be able to view the output by running xhost + in your command line and a pop-up window should show up. Please note that this will not work via SSH, you wuill need to access the system directly.
Jesus
JesusE_Intel
