Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1596 Discussions
extending walltime on specified node throws error
aanubhav
When i try running a job file named "jobfile", using the command:
qsub -l nodes=sxxx-nxxx My-Notebooks/job_file
it only runs for 10mins. To extend the wall time change the command to
qsub -l nodes=sxxx-nxxx,walltime=02:00:00 My-Notebooks/job_file
but this throws error, Alternately when i add the line -> "#PBS -l walltime=24:00:00" in my job file, same error is thrown again.
How can i extend the walltime on a targeted node.
Sahira_Intel
Hi aanubhav,
The walltime limit depends on the queue server and if you are using enterprise or academia version of the software. To query the limits, run the following command:
qmgr -c "p s" | grep walltime
Enterprise customers have a default limit of 1 hour and total maximum limit of 8 hours. Academia customers have a default limit of 10 minutes and total maximum limit of 20 minutes.
I hope this is helpful, please let me know if you have any more questions!
Sahira
Sahira_Intel
Hi aanubhav,
Sahira
Sahira_Intel
Hi aanubhav,
Since a solution was provided, this thread will be closed and no longer monitored. If you have a new question, please open a new thread.
Thank you!
Sahira
