Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
fatal error: 'CL/sycl/INTEL/fpga_extensions.hpp' file not found
za2561
I want to access Intel FPGAs through devcloud, I am new to cloud development so I used the easiest option which is Jupyter notebook.
I m trying to run Hough transform available as sample on the Jupyter notebook on intel oneapi devcloud, but when i tried to emulate the code through the following command:
icpx -fsycl -fintelfpga src/original/hough_transform.cpp -DFPGA_EMULATOR -o bin/hough_transform.emu
i got the following error:
src/original/hough_transform.cpp:8:10: fatal error: 'CL/sycl/INTEL/fpga_extensions.hpp' file not found
#include <CL/sycl/INTEL/fpga_extensions.hpp>
please help me to resolve this, and ill be very grateful
DiyaN_Intel
Thank you for posting in Intel communities.
Please try to make the following changes in the code and it will work perfectly, try to ignore the warnings if you get any.
In the hough_transform.cpp please make the below changes -
1. In line 9 change from
    to
#include <sycl/ext/intel/fpga_extensions.hpp>
2. In line 72 change from
sycl::INTEL::fpga_emulator_selector device_selector
    to
sycl::ext::intel::fpga_emulator_selector device_selector
3. In line 76 change from
sycl::INTEL::fpga_selector device_selector
    to
sycl::ext::intel::fpga_selector device_selector
In hough_transform_kernel.hpp please make the below changes -
  to
2. In line 30 change from
    to
3. In line 32 change from
  to
In addition, you can run the command (i.e. mkdir bin) to make the directory bin and proceed with the compilation like I did in the below screenshot.
If you face any issue please connect back to us.
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue. Thank you!
Diya
za25611
Thank you so much for your help diya, but now the jupyter doesn't recognize the dpcpp, as shown in code snippet below. it cannot even find icpx.
DiyaN_Intel
Hi ,
Could you please try setting up oneAPI environment variables forcefully and check once again if it is running properly or not.
Please run the below command:
source /opt/intel/oneapi/setvars.sh --force
If you face any issues please connect back to us.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Diya
za25611
Thanks a lot, the first line,
helped in setting the environment and i got the output
:: oneAPI environment initialized ::
but when i try to emulate i again get the error: /usr/bin/ld: cannot open output file bin/hough_transform.emu: No such file or directory, even though i created the bin directory, as can be seen in the attached pic
DiyaN_Intel
It seems like you have created the bin folder in the home directory.
Could you please create the bin folder in the mentioned path and try to run the code again:
~/Hough_Transform_on_FPGAs_Using_oneAPI/01_FPGA_Emulation_Using_Intel_oneAPI_Base_Toolkit
Diya
za25611
thank you,with your kind guidance, i have reached to the optimization stage,
Platform name: Intel(R) FPGA Emulation Platform for OpenCL(TM)
Device name: Intel(R) FPGA Emulation Device
Kernel execution time: 0.016045 seconds
VERIFICATION PASSED!!
The compile is finished.
but when i see reports.html in the
bin/unroll/hough_transform_split.prj/reports/report.html
nothing appears when i press trust html button, as shown in screenshot in the pic attached
although i can see the report_data.js file as below
DiyaN_Intel
Good day to you.
Glad to know that it is working for you now.
Can you please let us know if you have done any additional steps to get that report.html as well as report_data.js file generation as we can't see that in our notebook.
Diya
za25611
after getting: Kernel execution time: 0.016045 seconds
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI$ cd 02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit$ ! dpcpp -fintelfpga -fsycl-link -Xshardware src/split/main.cpp src/split/hough_transform_kernel.cpp -o bin/split/hough_transform_split.a
icpx: warning: use of 'dpcpp' is deprecated and will be removed in a future release. Use 'icpx -fsycl' [-Wdeprecated]
In file included from src/split/main.cpp:11:
src/split/hough_transform_kernel.hpp:11:10: fatal error: '../util/sin_cos_values.h' file not found
#include "../util/sin_cos_values.h"
1 error generated.
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit$ mkdir bin
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit$ cd bin
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit/bin$ mkdir split
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit/bin$ cd ..
Then i copied sin_cos_values.h in the folder util to the folder 02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit/util to the folder 02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit/src/split and changed the line in the file src/split/hough_transform_kernel.hpp:11:10 from #include "../util/sin_cos_values.h" to #include "sin_cos_values.h"
got many warnings
u182070@s001-n011:~/Hough_Transform_on_FPGAs_Using_oneAPI/02_FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit$ ! echo "The compile is finished."
then i followed the instruction in the  file as shown in following screenshot:
therefore, when i searched the path bin/split/hough_transform_split.prj/reports/report.html, i found the files
report_data.js and many. According to FPGA_Optimization_Report_Generation_Using_Intel_oneAPI_Base_Toolkit.pdf file, for getting reports, i need to open report.html file and press trust HTML, and pressing  is not giving any output.
DiyaN_Intel
We are investigating your issue at our end and working on this internally. We will get back to you with an update soon.
Diya
DiyaN_Intel
We tried to investigate the issue from our end and came up with a solution.
It seems like Jupyter has issues trying to load local HTML files even after pressing the "trust HTML" button.
https://github.com/jupyterlab/lumino/issues/240
So, please try to extract the "report.html" file from Jupyter and view it in a browser and you can view the reports.
If you face any issues, please connect back to us.
Diya
DiyaN_Intel
Good day to you.
We have not heard back from you. Could you let us know if your issue has been resolved with the above solution?
Diya
DiyaN_Intel
Good day to you.
We assume that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thanks and Regards,
Diya Nandy
