Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
gmp on devcloud
JSchr20
NOTE: This is a gmp question, not an FPGA question.
I have an OpenCL design for FPGA that requires gmp to verify results on the host.  I've installed a user copy in my home directory, but is there a centrally-installed version available somewhere?
JananiC_Intel
Thanks for reaching out.
Are you using Data centre devcloud or FPGA devcloud?
JSchr20
I'm using whichever cloud is accessed here: https://devcloud.intel.com/oneapi/
I don't think of it as an "FPGA cloud" since it has GPU and CPU nodes as well, but it's not a "Data Centre" cloud, either.  When I'm compiling my code, I do indeed submit a compile job to an fpga_runtime node.
Thank you!
JananiC_Intel
Thanks for the update.
The libgmp is installed in oneAPI devcloud.You can find libgmp.a in
/jhub/lib/
Also you can find header file in
/opt/.intel/inteloneapi/compiler/2021.1-beta04/linux/lib/oclfpga/linux64/lib/dspba/include
JananiC_Intel
Has your query been resolved?Could you please give us an update?
JSchr20
Hello -- I'm sorry, I haven't been able to try this yet, because for the last two days the cloud nodes have been very unresponsive, so I have not been able to get to the point in my work where I'm able to make this switch.  If the nodes are more responsive today, I will try it and let you know.
Thanks!
JSchr20
Thank you!  I was able to test the 'central' copy of gmp and it does appear to work just fine.  Much appreciated!
JananiC_Intel
Thanks for the update.We are closing the case.
Please feel free to raise a new thread in case of any further issues.
