I run a HPC application which needs a high-core-count cpu to check the OpenMP performance. Currently qsub allocates a computer node with only two 6-core CPUs. Is there a computer node with higher core count? Thanks.
Ed
Thank you for reaching out. According to your query, you require more than 6 cores per socket. Here are the nodes which fit this requirement:
1. In devcloud, nodes with cpu: i9-10920x have these features
> ncpus: 24
Thread(s) per core: 2
Core(s) per socket: 12
Socket(s): 1
To use those nodes, execute the below command which will provide the user with available node having these properties
qsub -I -l nodes=1: i9-10920x:ppn=2
2. The nodes with properties: renderkit
> ncpus: 64
Core(s) per socket: 16
Socket(s): 2
qsub -I -l nodes=1:renderkit:ppn=2
The nodes are subjected to availability. To know about the nodes, their properties, availability and for ncpus information, please execute the command :
pbsnodes
For more information on nodes and job submissions please refer: https://devcloud.intel.com/oneapi/documentation/job-submission/
Gopika
> ncpus: 24
Socket(s): 1
> ncpus: 64
Socket(s): 2
pbsnodes
Gopika
Thank you for accepting it as a solution. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Gopika
