Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
how to install?
remususu
this server does not allow you to run "sudo".
If you need to install a dependency, please put it in your home directory.
* For autotools, you can do it with "./configure --prefix=~/my-path"
* For Python packages, use "pip install <package_name> --user" or create a Conda environment.
Sincerely,
Admins
AthiraM_Intel
Thank you for sharing the details. Intel DevCloud® is a shared environment which comes with pre-installed validated Intel® oneAPI software and complimentary packages. In Intel Devcloud, there is no root access for users, so you cannot use sudo in DevCloud but you can install packages with pip and conda.
Could you please let us know whether we can close this case if you don't have any queries?
AthiraM_Intel
Could you please give us an update? Can we close this case?
AthiraM_Intel
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
