Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1641 Discussions
hpat on DevCloud
László_S_
I was hoping to experiment with hpat on the system, getting ready for data-intensive work in the cloud. However, I do not see it installed and even the preset channels do not include the module even though it is on the Intel channel on Anaconda, albeit with a 'test' label.
Please let me know if you could get hpat to work.
Adweidh_Intel
Kindly follow below steps to get hpat installed in a conda environment :
conda create -n env_hpat -c intel python=3.6
source activate env_hpat
conda install -c intel -c intel/label/test hpat
Try to import hpat from python terminal.
Hope this helps.
Adweidh_Intel
Hope this helps.
László_S_
Thanks, this sounds cool.
I must be confused by the setup though — if I installed everything from a terminal, why can't activate the environment in a new notebook?
!source activate env_hpat
gave me
/bin/sh: 1: source: not found
Adweidh_Intel
Kindly follow below steps to use your conda environment from jupyter notebook :
Activate the conda environment from the terminal.
Install ipykernel
conda install ipykernel
ipython kernel install --name env_hpat --user
Now open the jupyter and select the "env_hpat" from Kernel option. ( path : jupyter -> kernel -> change kernel -> env_hpat)
Hope this works !!
László_S_
Thanks again, so far so good!
Btw, a bland `conda update conda` before everything else failed, even though it attempted to update a surprising number of packages. (DevCloud promised to keep us on the bleeding edge, but you must know if some things are unstable or incompatible with other things.)
EnvironmentNotWritableError: The current user does not have write permissions to the target environment.
  environment location: /glob/intel-python/versions/2018u2/intelpython3
  uid: 34333
  gid: 34333
Adweidh_Intel
Hope your initial query was resolved.
Kindly raise a new thread for your new query.
Please confirm whether issue related to hpat on devcloud is resolved, so that we can close it !!
László_S_
Solved, please close the ticket.
Adweidh_Intel
This issue had been resolved and the thread is now closed. If you have a similar question, please start a new thread
