Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1591 Discussions
human_pose_estimation on DevCloud
VladT
hi. I try to setup and run human_pose_estimation_demo on different instances to get the FPS on different hardware. when I try to run human_pose_estimation_demo.py file it have several iports which is not possible to install on IntelDevCloud for Edge
#!pip install monitors - installed
#!pip install images_capture - not possible to install.It probably file or lib
#!pip install pipelines - installed but not possible import AsyncPipeline
#!pip install performance_metrics # - not possible to install.
without that modules human_pose_estimation_demo.py not working.
Could you please navigate me how to install or get that lib in to my intelDevCloud for Edge all the libs and dependency for that project.
JesusE_Intel
Hi VladT,
Instead of installing the modules, copy the common directory to your working directory. You can add the following line to your Jupyter Notebook.
!mkdir common
!cp -r /opt/intel/openvino_2021/inference_engine/demos/common/python/* common/
Assuming you are copying the human_pose_estimation_demo.py to DevCloud, modify line #28 to match the parent directory level.
sys.path.append(str(Path(__file__).resolve().parents[0] / 'common'))
The above steps should fix your import issues. Please note that additional changes may be required to get the demo working on DevCloud. I recommend following the Migrate from Edge Device tutorial under Advanced tutorials on DevCloud for guidance.
Jesus
Sahira_Intel
Hi VladT,
I apologize for the delay in my response! I am looking into this and will provide an answer shorty.
Sincerely,
Sahira
JesusE_Intel
Hi VladT,
!mkdir common
Jesus
VladT
hi Jesus.
Thanks a lot for that tip.
I try to do what you advise. Now I have the error on the next step.
File "human_pose_estimation_demo.py", line 32, in <module>
import models
File "/home/u71397/common/models/__init__.py", line 23, in <module>
from .open_pose import OpenPose
File "/home/u71397/common/models/open_pose.py", line 18, in <module>
import ngraph as ng
ModuleNotFoundError: No module named 'ngraph'
And again I can not install module - ngraph.
Defaulting to user installation because normal site-packages is not writeable
ERROR: Could not find a version that satisfies the requirement ngraph
ERROR: No matching distribution found for ngraph
Is it possible to solve that issue?
JesusE_Intel
Hi VladT,
Are you using the latest human_pose_estimation_demo.py code? I am not seeing any import errors after using the steps mentioned above. On DevCloud, ensure you are using OpenVINO 2021.3 Kernel.
Jesus
JesusE_Intel
