Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1665 Discussions
inference on node idc062 queued forever
KimChuan
#Submit job to the queue
job_id_c_FP16 = !qsub object_detection_job.sh -l nodes=1:idc062 \
-F "results/c/ GPU FP16 {InputVideo} 1" \
-N job_id_c_FP16 -o tmp -e tmp
print(job_id_c_FP16[0])
#Progress indicators
if job_id_c_FP16:
progressIndicator('results/c', f'pre_progress_{job_id_c_FP16[0]}.txt', "Preprocessing", 0, 100)
progressIndicator('results/c', f'i_progress_{job_id_c_FP16[0]}.txt', "Inference", 0, 100)
progressIndicator('results/c', f'post_progress_{job_id_c_FP16[0]}.txt', "Rendering", 0, 100)
ChrisB_Intel
IDC062 has been restored.
Chris
KimChuan
ChrisB_Intel
Are you manually choosing that node? That node isn't actually online, so it should go to the next available node, unless you are manually selecting that node. Would you mind sharing a bit more of the code? You can PM me if you would prefer.
Chris
ChrisB_Intel
Chris
