Thank you for posting in Intel communities.
Could you please let us know which DevCloud you are using (oneAPI/ Edge/ FPGA)?
From the error screenshot, the issue may be because you have ray.init() two times in your code. Could you please check that in your code?
If the issue persists, please share sample reproducer code and the exact steps you followed to try out the same from our end.
We have not heard back from you. Could you please give us an update?
env: Python 3.8 (Intel® oneAPI)
!pip install -U ray
!pip3 list | grep -i ray
import ray
ray.init(_memory=16000 * 1024 * 1024,object_store_memory=500 * 1024 * 1024,_driver_object_store_memory=500 * 1024 * 1024)
import modin.pandas as pd
import os
cwd = os.getcwd()
print(cwd)
df= pd.read_csv('/home/u151547/nlp/train.csv')
We are able to run the sample code without any error. Please see the below screenshot:
The issue may because you are running the same code again and again. Run the jupyter cell once and wait for the completion. Please restart the kernel if you want to run the code again.
We have marked the kernel restart icon in the screenshot.
Hope this will help. If you face any issue, please let us know.
Could you please give us an update? Is your issue resolved?
We have not heard back from you. This thread will no longer be monitored by Intel. If you need further assistance, please post a new question.
