Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1644 Discussions
kernal restart issue
Supriyo-ux
whenever i try to run any code it throws error.
JaideepK_Intel
Could you let us know whether you are using Intel DevCloud for oneAPI or Intel DevCloud for the Edge or DevCloud for FPGA ?
Jaideep
Supriyo-ux
hi thanks, i am using intel devcloud one api kernal for python, let me know if we have a screen sharing session via google meet
JaideepK_Intel
Can you please answer the following questions:
1. How often do you face this issue? Do you face this issue immediately after you launch jupyter notebook?
2. Can you run a command line interface? (via remote ssh)
Can you please try the below workarounds:
1. Delete your browser's cache and cookies and try to run in incognito mode.
2. If your application is running for longer than 6 hours, increase the "wall time." (-l walltime=hh:mm:ss)
We will connect with you through private message to get your DevCloud ID & error screenshots.
Jaideep
Supriyo-ux
i am getting on immediate effect .
here is my id-  (uxxxxx)
one new error message also coming like that-
it is unable to read also
JaideepK_Intel
Thanks for sharing the information. We are going to inform our admin team and get back to you with an update.
Jaideep
Supriyo-ux
any update?
JaideepK_Intel
The issue is related to the Ray component is allocating a lot of memory which is killing the Jupyter kernel.
Workaround solution is to start Ray with memory arguments to stay within limits like :
ray.init(
  _memory=16000 * 1024 * 1024,
  object_store_memory=500 * 1024 * 1024,
  _driver_object_store_memory=500 * 1024 * 1024)
Jaideep
Supriyo-ux
Hi i have added this:
import ray
ray.init(_memory=16000 * 1024 * 1024,object_store_memory=500 * 1024 * 1024,_driver_object_store_memory=500 * 1024 * 1024)
but still not working :
AttributeError                            Traceback (most recent call last)
Input In [5], in <cell line: 1>()
----> 1 import ray
      2 ray.init(_memory=16000 * 1024 * 1024,object_store_memory=500 * 1024 * 1024,_driver_object_store_memory=500 * 1024 * 1024)
File ~/.local/lib/python3.9/site-packages/ray/__init__.py:160, in <module>
    158 from ray.runtime_context import get_runtime_context  # noqa: E402
    159 from ray import autoscaler  # noqa:E402
--> 160 from ray import data  # noqa: E402,F401
    161 from ray import util  # noqa: E402
    162 from ray import _private  # noqa: E402,F401
File ~/.local/lib/python3.9/site-packages/ray/data/__init__.py:1, in <module>
----> 1 from ray.data.read_api import (
      2     from_items,
      3     range,
      4     range_arrow,
      5     range_tensor,
      6     read_parquet,
      7     read_json,
      8     read_csv,
      9     read_binary_files,
     10     from_dask,
     11     from_modin,
     12     from_mars,
     13     from_pandas,
     14     from_pandas_refs,
     15     from_numpy,
     16     from_arrow,
     17     from_arrow_refs,
     18     from_spark,
     19     read_datasource,
     20     read_numpy,
     21     read_text,
     22 )
     23 from ray.data.datasource import Datasource, ReadTask
     24 from ray.data.dataset import Dataset
File ~/.local/lib/python3.9/site-packages/ray/data/read_api.py:37, in <module>
     28 from ray.util.annotations import PublicAPI, DeveloperAPI
     29 from ray.data.block import (
     30     Block,
     31     BlockAccessor,
     35     BlockPartitionMetadata,
     36 )
---> 37 from ray.data.context import DatasetContext
     38 from ray.data.dataset import Dataset
     39 from ray.data.datasource import (
     40     Datasource,
     41     RangeDatasource,
     51     DefaultParquetMetadataProvider,
     52 )
File ~/.local/lib/python3.9/site-packages/ray/data/context.py:33, in <module>
     28 # Whether to furthermore fuse prior map tasks with shuffle stages.
     29 DEFAULT_OPTIMIZE_FUSE_SHUFFLE_STAGES = True
     32 @DeveloperAPI
---> 33 class DatasetContext:
     34     """Singleton for shared Dataset resources and configurations.
     35
     36     This object is automatically propagated to workers and can be retrieved
     37     from the driver and remote workers via DatasetContext.get_current().
     38     """
     40     def __init__(
     41         self,
     42         block_owner: ray.actor.ActorHandle,
     48         optimize_fuse_shuffle_stages: bool,
     49     ):
File ~/.local/lib/python3.9/site-packages/ray/data/context.py:42, in DatasetContext()
     32 @DeveloperAPI
     35
     38     """
     40     def __init__(
     41         self,
---> 42         block_owner: ray.actor.ActorHandle,
     43         block_splitting_enabled: bool,
     44         target_max_block_size: int,
     45         enable_pandas_block: bool,
     46         optimize_fuse_stages: bool,
     47         optimize_fuse_read_stages: bool,
     49     ):
     50         """Private constructor (use get_current() instead)."""
     51         self.block_owner = block_owner
AttributeError: partially initialized module 'ray' has no attribute 'actor' (most likely due to a circular import)
JaideepK_Intel
I assume there is some issue while downloading the ray package.
Please follow these steps:
If you are using a Jupyter notebook use the below command:
!pip install -U ray
or
If you are using terminal use the below command:
pip install -U ray
Below command to verify ray is installed properly or not:
!pip3 list | grep -i ray (Jupyter notebook)
pip3 list | grep -i ray (terminal)
Now import ray with the below command:
import ray
Jaideep
Supriyo-ux
new issue: not able to read csv file which can read in other local jupyter tool
JaideepK_Intel
Since you gave the wrong path, I assume you're getting this error.
correct path: /home/<user_id(example: u123456)>/nlp
So the command should look like this:
df=pd.read_csv("/home/<user_id(example: u123456)>/nlp/valid.csv")
Since you are in the same directory where valid.csv is present, you can also use the below command.
df=pd.read_csv("./valid.csv")
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Jaideep
JaideepK_Intel
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jaideep
