Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
limit qsub tasks runing simultaneously
tripto__eitamar
hello
i have a few hundreds of jobs that I want to use the devcloud for.
every job creates temporary files and that causing the storage to reach its maximum and then kills all processes (if 10 jobs run simultaneously ).
I wanted to know if there is a way to define that only 2-3 jobs (submitting by qsub) will run simultaneously
thank you
Eitamar
JEYANTHKRI_N_Intel
Hi , Thanks for reaching out to us. We hope that your job is storing something in your home folder. Thats why your storage space is occupied.Because,home folder is NFS-shared between the login node and the compute nodes. We recommend you to save the files in the /tmp folder of the compute node since the tmp folder gets cleared at end of every job completion. Please let us know if this resolves your issue.
tripto__eitamar
thank you for your quick reply.
i have two followup questions:
does the '/tmp' folder of the compute node have limitation on storage?
and is that storage part of the 200gb assign to every account?
JEYANTHKRI_N_Intel
"/tmp" folder in compute node possess 28gb.It is not part of 200gb storage assigned to each account. It is shared across all compute nodes and 90% is already used.
For better utilisation of the storage assigned to you,  please include files deletion as part of the script and to restrict the number of jobs run at a time you can check out -t option in the following link.
( link : http://docs.adaptivecomputing.com/torque/4-0-2/Content/topics/commands/qsub.htm )
tripto__eitamar
thanks!
I'll try the -t option once the current jobs end.
JEYANTHKRI_N_Intel
Hi ,
Could you please let us know if the solution provided helped?
tripto__eitamar
it seems like i don't understand the syntex of this commands, it didnt help me, i'll try to be clearer about my problem:
I have ~20 files named "launch{i}" (i=1,2,3...20)
#PBS
cd /home/u31124/
/usr/bin/time python script.py -p TARDBP -c 5 -A E
i am trying to run them using this loop file:
#!/bin/bash
for i in $(seq 1 26); do
        qsub launch$i
done
i would like to dubmit all 20 jobs but limit them to run 5 at a time.
when I changed the loop script to use the "-t" option like that:
#!/bin/bash
        qsub launch$i -t 0-10%4
done
I can submit only 9 jobs, and then get the response:
qsub: submit error (Maximum number of jobs already in queue for user MSG=total number of current user's jobs exceeds the queue limit: user u31124@login-1.aidevcloud, queue batch)
Lakshmi_U_Intel
Could you please try the below snippet. We have verified the same for a single job and it is working as per your requirement.
You just need to modify this code to run 5 jobs at a time.
#!/bin/bash
one=$(qsub script.sh)
echo $one
for id in seq 2 4; do
 two=$(qsub -W depend=afterok:$one script.sh)
 one=$two
done
Hope this helps. Thanks.
JEYANTHKRI_N_Intel
Could you please let us know whether the issue is resolved now?
