hello
i have a few hundreds of jobs that I want to use the devcloud for.
every job creates temporary files and that causing the storage to reach its maximum and then kills all processes (if 10 jobs run simultaneously ).
I wanted to know if there is a way to define that only 2-3 jobs (submitting by qsub) will run simultaneously
thank you
Eitamar
thank you for your quick reply.
i have two followup questions:
does the '/tmp' folder of the compute node have limitation on storage?
and is that storage part of the 200gb assign to every account?
"/tmp" folder in compute node possess 28gb.It is not part of 200gb storage assigned to each account. It is shared across all compute nodes and 90% is already used.
For better utilisation of the storage assigned to you, please include files deletion as part of the script and to restrict the number of jobs run at a time you can check out -t option in the following link.
( link : http://docs.adaptivecomputing.com/torque/4-0-2/Content/topics/commands/qsub.htm )
thanks!
I'll try the -t option once the current jobs end.
Hi ,
Could you please let us know if the solution provided helped?
it seems like i don't understand the syntex of this commands, it didnt help me, i'll try to be clearer about my problem:
I have ~20 files named "launch{i}" (i=1,2,3...20)
#PBS cd /home/u31124/ /usr/bin/time python script.py -p TARDBP -c 5 -A E
i am trying to run them using this loop file:
#!/bin/bash for i in $(seq 1 26); do qsub launch$i done
i would like to dubmit all 20 jobs but limit them to run 5 at a time.
when I changed the loop script to use the "-t" option like that:
#!/bin/bash for i in $(seq 1 26); do qsub launch$i -t 0-10%4 done
I can submit only 9 jobs, and then get the response:
qsub: submit error (Maximum number of jobs already in queue for user MSG=total number of current user's jobs exceeds the queue limit: user u31124@login-1.aidevcloud, queue batch)
Could you please try the below snippet. We have verified the same for a single job and it is working as per your requirement.
You just need to modify this code to run 5 jobs at a time.
#!/bin/bash one=$(qsub script.sh) echo $one for id in seq 2 4; do two=$(qsub -W depend=afterok:$one script.sh) one=$two done
Hope this helps. Thanks.
Could you please let us know whether the issue is resolved now?
