during my program, I'm using a lot of memory.
first of all, I wonder how can I check how much memory do I have?
and second, is there any way to increase the memory? maybe by paying money.
thanks,
my id is: uxxxxx
ilan.
Thanks for posting in Intel forums.
1)To check the available free space and utilization use the below command.
df -h
2)To analyze detailed disk utilization by each folder, run the below command.
du -sh *
du -sh <folder_name/filename>
Regarding your second question,devcloud memory is fixed we cannot increase devcloud memory.
Hope this helps!
Janani Chandran
Did that help? Do you have any update?
Janani Chandran
We assume that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
