Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
limited memory
ilanno
during my program, I'm using a lot of memory.
first of all, I wonder how can I check how much memory do I have?
and second, is there any way to increase the memory? maybe by paying money.
thanks,
my id is: uxxxxx
ilan.
JananiC_Intel
Thanks for posting in Intel forums.
1)To check the available free space and utilization use the below command.
df -h
2)To analyze detailed disk utilization by each folder, run the below command.
du -sh *
du -sh <folder_name/filename>
Regarding your second question,devcloud memory is fixed we cannot increase devcloud memory.
Hope this helps!
Janani Chandran
JananiC_Intel
Did that help? Do you have any update?
Janani Chandran
JananiC_Intel
We assume that your issue is resolved. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Janani Chandran
