I have access to Intel DevCloud to try oneAPI. and I use `qsub -I` to open interactive terminal
I tried to make FPGA examples, but `make fpga` shows this error:
[ 50%] Linking CXX executable ../triangular_loop.fpga
aoc: Quartus is not on the path!
aoc: Is it installed on your system and quartus bin directory added to PATH environment variable?
/home/u34315/tmp/triangular_loop-a503a1.o: file not recognized: File truncated
clang++: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
clang++: error: linker command failed with exit code 1 (use -v to see invocation)
src/CMakeFiles/triangular_loop.fpga.dir/build.make:94: recipe for target 'triangular_loop.fpga' failed
make[3]: *** [triangular_loop.fpga] Error 1
CMakeFiles/Makefile2:321: recipe for target 'src/CMakeFiles/triangular_loop.fpga.dir/all' failed
make[2]: *** [src/CMakeFiles/triangular_loop.fpga.dir/all] Error 2
CMakeFiles/Makefile2:264: recipe for target 'src/CMakeFiles/fpga.dir/rule' failed
make[1]: *** [src/CMakeFiles/fpga.dir/rule] Error 2
Makefile:183: recipe for target 'fpga' failed
make: *** [fpga] Error 2
If I source `init_opencl.sh` from different pre-installed quartus version I get version incompatibility error.
Could you please tell me which script should I source exactly to be able to use installed PAC on the DevCloud?
the aocl diagnose all command shows:
ICD System Diagnostics
Using the following location for ICD installation:
/etc/OpenCL/vendors
Found 4 icd entry at that location:
/etc/OpenCL/vendors/intel-cpu.icd
/etc/OpenCL/vendors/intel-neo.icd
/etc/OpenCL/vendors/Altera.icd
/etc/OpenCL/vendors/Intel_FPGA_SSG_Emulator.icd
the following OpenCL libraries are referenced in the icd files:
libintelocl.so
libigdrcl.so
libalteracl.so
libintelocl_emu.so
checking LD_LIBRARY_PATH for registered libraries:
libintelocl.so was registered on the system at /opt/intel/inteloneapi/compiler/latest/linux/lib/x64
libigdrcl.so was registered on the system at /opt/intel/inteloneapi/compiler/latest/linux/lib/oclgpu
libalteracl.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/host/linux64/lib
libintelocl_emu.so was registered on the system at /opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/host/linux64/lib
Using the following location for fcd installations:
/opt/Intel/OpenCLFPGA/oneAPI/Boards
ERROR: no FCD entry at that location. Without ICD and FCD, host executables must be linked directly to Intel FPGA runtime (libalteracl) and BSP MMD library instead of to the khronos ICD library (libOpenCL).
To use FCD, Please reinstall using aocl install
ICD diagnostics FAILED
BSP Diagnostics
/opt/intel/inteloneapi/compiler/2021.1-beta03/linux/lib/oclfpga/board/intel_a10gx_pac/linux64/libexec/diagnose: error while loading shared libraries: libopae-c.so.1: cannot open shared object file: No such file or directory
my user is u34315@s001-n123
- Tags:
- General Support
Hi Amiri,
Please use "make fpga_emu" command instead of "make fpga", as we are having FPGA Emulation device on devcloud.
For more information, please refer README.md file which is provided along with samples.
Link for README.md file:
Note: Please use "qsub -I -l nodes=1:fpga_compile:ppn=2" command for entering into interactive terminal. (1st arg: Captial i (-I), 2nd arg: Small L(-l)).
Please let us know if this resolves your issue.
Goutham
Hi Amiri,
We are working on this issue and will get back to you.
Goutham
Hi Amiri,
Goutham
For hardware compilation please read my post:
https://software.intel.com/en-us/forums/intel-devcloud/topic/840128
I hope it can save you time.
@Tyurin Apperantely not all nodes on the cloud have FPGA hardware installed. As suggested by you and @kunscham I used
to enter in interactive mode, and it actually did the trick. I can compile and execute on real FPGAs now.
Hi Amiri,
Glad to hear that the solution provided helped.
We are closing this thread, Feel free to raise a new thread in case of any further issues.
Have a good day!
Goutham
