Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1467 Discussions
new kernel connecting failure
Liu__Yuhan
I created a new kernel with my own enviroment
But it still using the glob enviroment
I open the kernel.json file of my kernel
 "argv": [
  "/glob/intel-python/versions/2018u2/intelpython3/bin/python",
  "-m",
  "ipykernel_launcher",
  "-f",
  "{connection_file}"
 "display_name": "lyhpy36_2",
 "language": "python"
Here in "argv" it still use the python of "/glob" instead of "/uxxxxx/.conda/envs/xxxx"
So I changed "/glob/intel-python/versions/2018u2/intelpython3/bin/python", to "/uxxxxx/.conda/envs/xxxxxxxxx/xxxxxx"
And then my kernel has connecting failure.
I wonder why and how can I use my kernel with my own enviroment instead of the global one.
Liu__Yuhan
By the way,  I already "source activate my_env" before I create the new kernel
AthiraM_Intel
We understand your concern. Could you please verify whether you face the same issue with a newly created environment.
Please follow the below steps.
1. Create a new environment
conda create --name <env_name>
2. Activate the new environment
source activate <env_name>
3. To add new kernel
ipython kernel install --name "env_name" --user
4. Open jupyter terminal  and give
cd /home/u*****/.local/share/jupyter/kernels/<env_name>
5. Open kernel.json and check if the python path referenced is /glob python or path to your <env_name>. If it is /glob python, change the path to
/home/u*****/.conda/envs/<env_name>/bin/python
6. Open the terminal and activate new environment.
7. Check the path of Python by giving the following command: which python. If it references /glob python path, update the PATH by exporting the conda python path.
export PATH="/home/u*****/.conda/envs/<env_name>/bin":$PATH
8. On checking which python, it should show the updated python PATH.
Please verify and let us know if the solution provided worked. If the issue still persists, share the steps you have followed with the corresponding screenshots.
AthiraM_Intel
Could you please confirm whether your issue got resolved?
Liu__Yuhan
I have done it according to the direction you gave me.
But I cannot connect to the kernel and got this all the time until the connection fails.
It said "Kernel starting please wait"
Liu__Yuhan
AthiraM_Intel
We understand your concern. We have informed the concerned admin team regarding your issue.
AthiraM_Intel
Could you please check if the issue exists. If it still persists, we will create a new account for you.
JananiC_Intel
Could you please give us an update?
AthiraM_Intel
Hope your issue got resolved. We are closing this thread. Please feel free to open a new thread if you have any further queries.
