I was trying to build a very simple example on Arria 10 OneAPI Node, and got errors similar to https://community.intel.com/t5/Intel-DevCloud/Devcloud-OneAPI-FPGA-compilation-error/td-p/1500724 . Here are the steps to reproduce the error:
Step 1: To get arria10 node
qsub -I -l nodes=1:arria10:ppn=2 -d .
Step 2: Create a simple source file
echo "int main() {}" > test.cpp
Step 3: Build for FPGA
icpx -fsycl test.cpp -Xshardware -fintelfpga -Xstarget=intel_a10gx_pac:pac_a10 -o test.fpga
And after a few minutes, the compiler reports errrors:
Error (18640): The Quartus Partition Database File '/home/u172305/tmp/test-73c90c-3111fa/build/dcp.qdb' was generated using version 'Version 19.2.0 Build 57 06/24/2019 SJ Pro Edition', which cannot be read by the current version of the Quartus Prime software. Regenerate '/home/u172305/tmp/test-73c90c-3111fa/build/dcp.qdb' using the current version of the Quartus Prime Software.
Error (18640): The Quartus Partition Database File '/home/u172305/tmp/test-73c90c-3111fa/build/green_region.qdb' was generated using version 'Version 19.2.0 Build 57 06/24/2019 SJ Pro Edition', which cannot be read by the current version of the Quartus Prime software. Regenerate '/home/u172305/tmp/test-73c90c-3111fa/build/green_region.qdb' using the current version of the Quartus Prime Software.
Error: Flow failed: 0x9c30500
Error: Quartus Prime Synthesis was unsuccessful. 3 errors, 232 warnings
Error (23035): Tcl error:
Error (23031): Evaluation of Tcl script compile_script.tcl unsuccessful
Error: Quartus Prime Shell was unsuccessful. 2 errors, 0 warnings
Error (23031): Evaluation of Tcl script build/entry.tcl unsuccessful
For more details, full Quartus compile output can be found in files quartuserr.tmp and quartus_sh_compile.log.
Error: Compiler Error, not able to generate hardware
llvm-foreach:
icpx: error: fpga compiler command failed with exit code 1 (use -v to see invocation)
I also tried the workaround mentioned at community.intel.com/t5/Intel-DevCloud/Devcloud-OneAPI-FPGA-compilation-error/m-p/1507309#M8477 , it works for me. But it uses an old version of oneapi (2023.0), is there any way I can compile with the new version of oneapi (2023.2)?
Seems like the problem has been fixed, to using oneAPI 2023.2, just run
source /glob/development-tools/versions/oneapi/2023.2.0.1/oneapi/setvars.sh --force
Glad to know that your issue is resolved. Thanks for sharing it with the community. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Thasneem Vazim
