Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1642 Discussions
oneAPI FPGA optimization report not working
DeepikaGanga
I am working with the Hough Transform program in the Jupyter oneAPI notebook on DevCloud. This is a oneAPI program which is created for FPGA, there are 3 parts to this program as shown below, I am facing an issue with the second part which is generating FPGA Optimization report.
The code executes correctly and the reports folder and files are created. But the report.html file doesn't open even after following the step of enabling "Trust Html".  A similar issue was raised in the forum, I tried querying in that thread as well, but there was no response, the link to the same is https://community.intel.com/t5/Intel-High-Level-Design/oneAPI-optimization-report-error/m-p/1378196/emcs_t/S2h8ZW1haWx8dG9waWNfc3Vic2NyaXB0aW9ufEwyNkRQSEJLWjJURTJBfDEzNzgxOTZ8U1VCU0NSSVBUSU9OU3xoSw#M2434
Below are the steps followed which generates a report.html file but doesn't show anything. Please clarify.
______________________________________________________________________________________
BoonBengT_Intel
Hi @DeepikaGanga,
My guess is there might be some missed files in the .prj folder during the zip.
I was able to zip and download to view the report as followed:
Hence would suggest to double check on the missing folder during zip.
Best Wishes
BB
DeepikaGanga
Can someone give me some pointers here please?
BoonBengT_Intel
Hi @DeepikaGanga,
Thank you for posting in Intel community forum and hope all is well.
If understand the situation correctly, you managed to compile the project successfully and are having problem in reading the report details.
As mention in the previous post you would be able to zip and download it via jupyter.
In this case you can zip the entire .prj folder, just cd to that path and run the below command:
& zip -r temp.zip hough_transform_split.prj
You would be able to download the report and should be seeing more details.
Hope that clarify.
Best Wishes
BB
DeepikaGanga
Hi BB,
Thanks for your response, I tried zipping the reports folder and opening it locally, but it still doesn't work. Please see the image below:
Deepika
BoonBengT_Intel
Hi @DeepikaGanga,
Best Wishes
BB
DeepikaGanga
Thanks BB, I was finally able to view the report.
BoonBengT_Intel
Hi @DeepikaGanga,,
Great! Good to know that it is working now, with no further clarification on this thread, it will be transitioned to community support for further help on doubts in this thread.
Thank you for the questions and as always pleasure having you here.
Best Wishes
BB
