Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1663 Discussions
oneapi/pytorch import error when importing torch - GLIBC_2.28 not found
mike02
Hello
Recently I encounter this error when importing torch in my python code. This is a simple repro of the error
~$ ipython
Python 3.9.16 (main, Jun 15 2023, 02:33:25)
In [1]: import torch
ImportError                               Traceback (most recent call last)
Cell In[1], line 1
----> 1 import torch
File /glob/development-tools/versions/oneapi/2023.2.0.1/oneapi/pytorch/2.0.1.0/lib/python3.9/site-packages/torch/__init__.py:229
--> 229     from torch._C import *  # noqa: F403
ImportError: /lib/x86_64-linux-gnu/libc.so.6: version `GLIBC_2.28' not found (required by /glob/development-tools/versions/oneapi/2023.2.0.1/oneapi/pytorch/2.0.1.0/lib/python3.9/site-packages/torch/lib/libtorch_cpu.so)
Checking the version of libc.so.6, it appears I have Ver 2.27 .
ls -la /lib/x86_64-linux-gnu/libc.so.6
lrwxrwxrwx 1 root root 12 Apr 16 2018 /lib/x86_64-linux-gnu/libc.so.6 -> libc-2.27.so
Is it possible to upgrade the version?
mike02
Sorry for the false alarm. I experience the error from the login shell. However if I create  an interactive  cloud shell then the issue goes away since the libraries are up to date.
u192355@s019-n020:~$ ls -la /lib/x86_64-linux-gnu/libc.so.6
lrwxrwxrwx 1 root root 12 Apr 6 2022 /lib/x86_64-linux-gnu/libc.so.6 -> libc-2.31.so
So my issue is resolved and this can be closed. I apologize for the extra noise
VaradJ_Intel
Good day to you.
Glad to know that your issue is resolved.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Thank You!
Varad
