I'm trying to install tensorflow using pip, but whenever I try to do it, it gives an error saying "Could not find a version that satisfies the requirement TensorFlow (from versions: none)". Please advice me about how I could fix this problem
Thanks!
Thanks for posting in Intel Forum.
Could you try installing tensorflow from compute node?
For your information, login node uses a lightweight general-purpose processor. Login nodes should not be used for development or execution of programs. It is an interface node that helps to connect or submit jobs to compute nodes.
DevCloud does not allow external website access from the login node. External access is allowed only from compute nodes.
As you already know, we can use compute nodes to download or clone repositories.
Janani Chandran
Is your issue resolved? Do you have any updates?
Janani Chandran
Thank you for the help. I read some more documentation, and with your comment I understood how to fix it. Thank you!
Nividh Singh
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
