hello,
How can I make python 3.8 as default python, how can I install packages that are required python 3.8 and above ?
thank you,
WE
If you are using Jupyter Hub you are already in a compute note.
You can directly open terminal from there it will connected to compute node and use it.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Shyam Sundar
You can use the below command for creating a virtual environment with python 3.8.
conda create -n <env name> intelpython3_full python=3.8
Then, activate the environment as follows:
conda activate <env_name>
Shyam Sundar
Hello Shyam Sundar,
How can I connect this <env_name> to jupyter notebook ?
thank you,
WE
Follow these commands in DevCloud (Jupyter Notebook/ Terminal)
If you not created any new environment create one using:
1. Activate the new environment
source activate <env_name>
2. Install ipykernel
conda install ipykernel
3. Add new kernel in jupyter notebook
python -m ipykernel install --user --name <env_name>
4. Open the jupyter lab and set the kernel to this environment
Kernel-->change kernel --> select one you want
Shyam Sundar
Hello Shyam Sundar,
how can I enable this in the job file, when I use qsub command to submit job?
Thank you for your great answers, I appreciate your help and support.
regards
WE
Shyam Sundar
Could you please give us an update? Is your issue resolved?
Shyam Sundar
Hello Shyam,
Thank you for the great efforts and detailed reply. How can I inform the qsub in the shell script file to use this new version of python instead of the default python ?
thank you,
WE
Add below lines to the job script file (.sh file) to activate and use an environment when submitting job to Intel DevCloud:
eval "$(conda shell.bash hook)"
conda activate <env-name>
<commands>
Thus we can run with any environment while using qsub
Shyam Sundar
Shyam Sundar
Thanks Shyam!, the problem is solved.
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Shyam Sundar
