Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1462 Discussions
qdel: Server could not connect to MOM 982005.v-qsvr-1.aidevcloud
HYB
Deleting the queue task failed, and the task was not automatically stopped after more than 12 hours.
uxxxxx@s001-n061:~/atest$ qdel 982005
AlekhyaV_Intel
We are working on this internally. We will get back to you soon with an update.
Alekhya
AlekhyaV_Intel
We've deleted the job from our end. Could you please check and confirm the same?
Alekhya
HYB
Thank you for your help. The previous task has been deleted, but there will be new tasks that cannot be deleted later. Is there any way to solve this problem without bothering you
GRN2
The reason of your issue can be that your job is too hard for compute node. For example, extra memory consumption.
One more reason: GPU driver may hang during kernel execution of your sample, and hang the compute node.
It would be nice to check the sample on local machine before submitting on DevCloud.
AlekhyaV_Intel
As you were unable to delete another two jobs, could you please share with us the job IDs so that we will delete them from our end?
Alekhya
AlekhyaV_Intel
Could you please give us an update regarding your issue?
Alekhya
AlekhyaV_Intel
We assume that your issue is resolved. If you need any further assistance, please post a new question as this thread will no longer be monitored by Intel.
Alekhya
