Good afternoon:
Failed to run command when trying Intel oneAPI Base Toolkit Samples
qsub -l nodes=1:gpu:ppn=2 -d . build.sh
Unable to communicate with v-qsvr-1.aidevcloud(10.9.0.131)
Cannot connect to specified server host 'v-qsvr-1.aidevcloud'.
qsub: cannot connect to server v-qsvr-1.aidevcloud (errno=111) Connection refused
qstat
qstat: cannot connect to server v-qsvr-1.aidevcloud (errno=111) Connection refused
qstat: Error (111 - Connection refused)
- Tags:
- General Support
Your issue is resolved. Please find the below screenshot. Could you check again and let us know?
Janani Chandran
I'm also experiencing the same issue since the last 2 days. Any idea on how to check if the server is available or when this will be fixed?
Thanks for posting in Intel forums.
Today we tried the same from our end. You can find the screenshot below. We couldn't find any issues, so this might be a temporary issue. Try again and let us know if the issue persists.
Janani Chandran
Sorry for the inconvenience. We reproduced your issue and we are working on it. We will get back to you soon.
Janani Chandran
Janani Chandran
Is your issue resolved? Do you have any update?
Janani Chandran
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Janani Chandran
