Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1593 Discussions
qstat -xf job# output is unreadable
segmentation_fault
If I do "qstat -xf my_job_number" I get unreadable output. It appears to be JSON or some XML formatted output. In most clusters I have worked in the output is human readable with line breaks and tabs.
me@s001-n064:~/solver$ qstat -xf | grep exec
<Data><Job><Job_Id>993274.v-qsvr-1.aidevcloud</Job_Id><Job_Name>build.sh</Job_Name><Job_Owner>me@login-2.aidevcloud</Job_Owner><resources_used><cput>00:23:37</cput><energy_used>0</energy_used><mem>7957620kb</mem><vmem>28333580kb</vmem><walltime>00:06:20</walltime></resources_used><job_state>R</job_state><queue>batch</queue><server>v-qsvr-1.aidevcloud</server><Checkpoint>u</Checkpoint><ctime>1634660512</ctime><Error_Path>login-2.aidevcloud:/home/me/solver/build.sh.e993274</Error_Path><exec_host>s001-n021/0-1+s001-n064/0-1</exec_host><Hold_Types>n</Hold_Types><Join_Path>n</Join_Path><Keep_Files>n</Keep_Files><Mail_Points>n</Mail_Points><mtime>1634660513</mtime><Output_Path>login-2.aidevcloud:/home/me/solver/build.sh.o993274</Output_Path><Priority>0</Priority><qtime>1634660512</qtime><Rerunable>True</Rerunable><Resource_List><nodect>2</nodect><nodes>2:ppn=2</nodes><walltime>06:00:00</walltime></Resource_List><session_id>1071165</session_id><Variable_List>PBS_O_QUEUE=batch,PBS_O_HOME=/home/me,PBS_O_LOGNAME=me,PBS_O_PATH=/glob/development-tools/versions/ispc/ispc-v1.13.0-linux/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/vtune/2021.7.1/bin64:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/vpl/2021.6.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/ospray_studio/0.8.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/ospray/2.7.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/openvkl/1.0.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/oidn/1.4.1/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/mpi/2021.4.0//libfabric/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/mpi/2021.4.0//bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/mkl/2021.4.0/bin/intel64:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/itac/2021.4.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/intelpython/latest/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/intelpython/latest/condabin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/inspector/2021.4.0/bin64:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/embree/3.13.1/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/dpcpp-ct/2021.4.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/dev-utilities/2021.4.0/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/debugger/10.2.4/gdb/intel64/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/compiler/2021.4.0/linux/lib/oclfpga/llvm/aocl-bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/compiler/2021.4.0/linux/lib/oclfpga/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/compiler/2021.4.0/linux/bin/intel64:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/compiler/2021.4.0/linux/bin:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/clck/2021.4.0/bin/intel64:/glob/development-tools/versions/oneapi/2021.4/inteloneapi/advisor/2021.4.0/bin64:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/home/me/.local/bin:/home/me/bin:/bin,PBS_O_MAIL=/var/mail/me,PBS_O_SHELL=/bin/bash,PBS_O_LANG=en_US,PBS_O_SUBMIT_FILTER=/usr/local/sbin/torque_submitfilter,PBS_O_INITDIR=/home/me/solver/.,PBS_O_WORKDIR=/home/me/solver,PBS_O_HOST=login-2.aidevcloud,PBS_O_SERVER=v-qsvr-1.aidevcloud</Variable_List><euser>me</euser><egroup>me</egroup><queue_type>E</queue_type><etime>1634660512</etime><submit_args>-l nodes=2:ppn=2 -d . build.sh</submit_args><start_time>1634660513</start_time><Walltime><Remaining>21143</Remaining></Walltime><start_count>1</start_count><fault_tolerant>False</fault_tolerant><job_radix>0</job_radix><submit_host>login-2.aidevcloud</submit_host></Job></Data>
JyothisV_Intel
We were able to replicate this from our end. Can you try checking the job status using the following command without the -x option:
qstat -f job# | grep exec
(Replace job# with the Job ID)
You can read more about this here: https://devcloud.intel.com/oneapi/documentation/advanced-queue/
If this resolves your issue, make sure to accept this as a solution. This would help others with a similar issue.
Thank You!
Jyothis V James
JyothisV_Intel
Thank You!
Jyothis V James
JyothisV_Intel
Thanks for accepting our solution.
If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
Jyothis V James
