I get the following error message when I try to use qsub from login-2:
u31296@login-2:~$ qsub -I
qsub: submit error (Bad UID for job execution MSG=ruserok failed validating u31296/u31296 from login-2.aidevcloud)
I get the same error if I try to submit a PBS script.
- Tags:
- General Support
Hey Henry,
Are you able to access devcloud using the jupyter notebook ?
Could you also run the below command from your login node and let us know the result.
qmgr -c 'l s' | grep allow_node_submit
Hi Arun,
The qsub command appears to be working again on login-2. Here's the result of the qmgr command:
u31296@login-2:~$ qmgr -c 'l s' | grep allow_node_submit
allow_node_submit = True
Henry
Hi Henry,
Thanks for confirming your issue is resolved. We are closing this thread please feel free to raise a new thread in case of further issues.
Arun Jose
