Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1474 Discussions
s001-n084 terminates early/randomly
PSath2
s001-n084 terminates interactive sessions randomly. Sometimes I can run for a few minutes, sometimes it terminates the connection right after login.
I don't have any other jobs in any other queues, but keep landing on n084 when I request an arria10 in the default queue.
PSath2
Interactive jobs also occasionally get "apparently deleted" while waiting in queue "v-qsvr-1.aidevcloud"
@login-1:~$ qsub -V -l nodes=ppn=2:arria10  -I
qsub: waiting for job 435172.v-qsvr-1.aidevcloud to start
qsub: job 435172.v-qsvr-1.aidevcloud apparently deleted
PSath2
Seems like this might be specific to node 84, not the whole queue. If I manually select node 91, which is in the same queue and also has the arria10 property, my interactive build job still hasn't been terminated after ~40 minutes
JEYANTHKRI_N_Intel
Hi ,
We will contact the DevCloud admin team and get back to you .
JEYANTHKRI_N_Intel
Apologies for the delayed response. Our DevCloud Admin team needs some more time to debug the problem.Will get back to you as soon as we get a response from them.
Andrey_Vladimirov
New Contributor III
Hi Paul, you need to change the -l argument like this: "-l nodes=1:ppn=2:arria10". Without it, the job will reserve only half a node and will get terminated by the cloud's automation. You always need the "1:" when requesting a node by its property. However, when you are requesting a node by its hostname, you should not use the "1:", e.g., "-l nodes=s001-n084:ppn=2".
JEYANTHKRI_N_Intel
Could you please let us know if the solution provided helped?
STyur
Best way for simple use is to add the follow aliases to ~/.bashrc
alias cifpga='qsub -I -l nodes=1:fpga_compile:ppn=2 -d .'
alias cbfpga='qsub -l nodes=1:fpga_compile:ppn=2,walltime=24:00:00 -d .'
alias rifpga='qsub -I -l nodes=1:fpga_runtime:ppn=2 -d .'
alias rbfpga='qsub -l nodes=1:fpga_runtime:ppn=2,walltime=24:00:00 -d .'
And after that you can connect interactivle or send a job by one simple commad:
interactive ligin to compilation server:
cifpga
send compilation job:
cbfpga <you script file>
interactive ligin to fpga server:
rifpga
send fpga job:
rbfpga <you script file>
