Because the new ssh setting, I used the following configurations and regenerated known_hosts. However, when ssh devcloud.proxy I still got an error. Could you check the error? Thank you so much.
-------- configuration below --------
Host devcloud.proxy
User u154255
Port 4022
IdentityFile ~/.ssh/devcloud-access-key-154255.txt
ProxyCommand ssh -T devcloud-via-proxy
Host devcloud-via-proxy
User guest
Hostname ssh.devcloud.intel.com
LocalForward 4022 c009:22
ProxyCommand nc -x proxy-dmz.intel.com:1080 %h %p
------- error message below ------
guest@ssh.devcloud.intel.com: Permission denied (publickey).
kex_exchange_identification: Connection closed by remote host
Connection closed by UNKNOWN port 65535
UPDATE: Seems to be working now
I am seeing the same error. I have regenerated my config and made sure to use the new devcloud-access-key-NNNNNN.txt. I can download the new key and access Jupyter notebooks, so I don't think my accound has been disabled (mentioned in a different thread)
I also get the exact same error. I tried to reconfigure ssh connection from scratch (config, know_hosts and private key file regenerated using the script provided in the ssh setup page) but still doesn't work.
It seems the issue has been solved (at least for me), it is working fine now.
ssh to DevCloud is working now. Thank you so much for the assistance.
We sincerely apologize for the inconvenience caused. DevCloud was down from past few days and it is fixed now.
@Cheng-Hsiang @DanDaMan @mapenzo Glad to know that your issues are resolved. Thanks for sharing the updates with us. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
