Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1474 Discussions
the ssh connection stuck at "debug2: we sent a publickey packet, wait for reply".
JunyLim
My devcloud ID is u166274.
I used to ssh devcloud successfully yesterday and before but today the ssh connection stuck at "debug2: we sent a publickey packet, wait for reply".
The ~/.ssh/config file is as below:
Host devcloud
User u166274
IdentityFile ~/.ssh/devcloud-access-key-166274.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-166274.txt guest@ssh.devcloud.intel.com
For the moment, I still can access devcloud with Jupyter notebook.
Any advice would be appreciated.
FelipeML
Hi!
I have the same problem. Mi devcoud ID is u137524.
Yesterday I commented in this post that I was experiencing a longer than normal connection time:
https://community.intel.com/t5/Intel-DevCloud/Abnormal-Connection-Time/m-p/1416191#M6095
Today I can only connect to devcloud using jupyter notebook.
Björne
I can't connect either.  It is stuck at "debug1: Server accepts key: /path/to/my/key"  Now it works. It's really slow though.
ShyamS_Intel
Issue is resolved now. Please try to connect to DevCloud and let us know.
If this resolves your issue, make sure to accept this as a solution. This would help others with similar issue. Thank you!
Please let us know if we can close this case.
Shyam Sundar
ShyamS_Intel
Could you please provide any update?
Shyam Sundar
JunyLim
Yeap, i can connect thru ssh now. Thanks
ShyamS_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Shyam Sundar
