Dear all,
can anybody help? I cannot access devcloud via ssh.
Dirk
Thank you for posting in Intel communities.
The public key permission denied error was due to a bug on the web portal SSO introduced Thursday July 14th at ~1pm and resolved at ~10am July 15th. In fixing this bug, if you are still getting this error, please down load the public key as shown in the credentials email.
If you are still facing the issue, please let us know.
the problem still exists. I cannot establish a ssh connection with the devcloud. I always get the message: permission denied. Moreover, I cannot download a new setup bash script. I should first enroll for devcloud. If I do so, I get the message that my account already exist.
Dirk
We are extremely sorry for the inconvenience caused. Kindly follow the below steps.
Steps to check your account and remediate:
1. Sign into DevCloud : https://devcloud.intel.com/oneapi/
2. Login/launch Jupyter – Launch Jupyter
3. Note down account number as shown below in the Welcome.ipynb notebook
4. Next, login with ssh – if error does not show up your account is good.
5. if permission denied(public key) error message shows up during login with ssh then:
a. Check your .ssh/config : cat .ssh/config
b. Does your account number in your ssh/config match with the one showed in in Jupyter(Example : 12345)
c. Make sure correct account number is reflected in the config file. If not, edit your .ssh/config to correct the account number in .ssh/config to be same as the one with what you see in Jupyter
d. Login with ssh again
If at any point during the above steps you notice files missing please contact us with your original account number and the correct account number – we will work with the engineering team to help assist copy your files over.
We apologize for this inconvenience cause by the public key error issue.
Hey,
thank you very much, but it does not help. If I sign into Jupyter, I get the message that I have to enroll for devcloud (see figure in the attachment.
Please note, I already extended my account some weeks ago. Since that time, I am not able to access devcloud although the extension was successful. If I enroll again, I get the message that the enrollment does not work (see second figure in the attachment).
Thus, I cannot access Jupyter to follow your steps. Can you reset my account completely? May this will help.
Thanks and Best,
Dirk
We have applied a backend fix to Jupyter/ssh at 7:55 PM on 31st July, 2022
Please try Jupyter and let us know, if you are still facing any issues
We apologize for the inconvenience caused.
Could you please give us an update? Is your issue resolved?
We assume that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
