Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1626 Discussions
unable to connect to devcloud
paul24
paul@mars:~> ssh -v devcloud
OpenSSH_8.4p1, OpenSSL 1.1.1d 10 Sep 2019
debug1: Reading configuration data /home/paul/.ssh/config
debug1: /home/paul/.ssh/config line 8: Applying options for devcloud
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 20: Applying options for *
debug1: Executing proxy command: exec ssh -T -i ~/.ssh/devcloud-access-key-163970.txt guest@ssh.devcloud.intel.com
debug1: identity file /home/paul/.ssh/devcloud-access-key-163970.txt type -1
debug1: identity file /home/paul/.ssh/devcloud-access-key-163970.txt-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_8.4
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
debug1: match: OpenSSH_7.6p1 Ubuntu-4ubuntu0.3 pat OpenSSH_7.0*,OpenSSH_7.1*,OpenSSH_7.2*,OpenSSH_7.3*,OpenSSH_7.4*,OpenSSH_7.5*,OpenSSH_7.6*,OpenSSH_7.7* compat 0x04000002
debug1: Authenticating to devcloud:22 as 'u163970'
debug1: SSH2_MSG_KEXINIT sent
debug1: SSH2_MSG_KEXINIT received
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: curve25519-sha256 need=64 dh_need=64
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:7R/nUuhf2mWQej8YRr+FNr0T0++Rw71wmvZpsrysbFU
debug1: Host 'devcloud' is known and matches the ECDSA host key.
debug1: Found key in /home/paul/.ssh/known_hosts:13
debug1: rekey out after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug1: SSH2_MSG_NEWKEYS received
debug1: rekey in after 134217728 blocks
debug1: Will attempt key: /home/paul/.ssh/devcloud-access-key-163970.txt explicit
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug1: Authentications that can continue: publickey
debug1: Next authentication method: publickey
debug1: Trying private key: /home/paul/.ssh/devcloud-access-key-163970.txt
^C
hangs
paul@mars:~> ssh -v -i ~/.ssh/devcloud-access-key-163970.txt guest@ssh.devcloud.intel.com
debug1: Connecting to ssh.devcloud.intel.com [12.229.61.118] port 22.
debug1: Connection established.
debug1: Remote protocol version 2.0, remote software version OpenSSH_8.2p1 Ubuntu-4ubuntu0.5
debug1: match: OpenSSH_8.2p1 Ubuntu-4ubuntu0.5 pat OpenSSH* compat 0x04000000
debug1: Authenticating to ssh.devcloud.intel.com:22 as 'guest'
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:fdh1CzIao2MCh6YQ3uP7ZZyZF0XqieU7OY6DjcDctq4
debug1: Host 'ssh.devcloud.intel.com' is known and matches the ECDSA host key.
debug1: Found key in /home/paul/.ssh/known_hosts:12
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,sk-ssh-ed25519@openssh.com,ssh-rsa,rsa-sha2-256,rsa-sha2-512,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,sk-ecdsa-sha2-nistp256@openssh.com>
debug1: Authentication succeeded (publickey).
Authenticated to ssh.devcloud.intel.com ([12.229.61.118]:22).
debug1: channel 0: new [client-session]
debug1: Requesting no-more-sessions@openssh.com
debug1: Entering interactive session.
debug1: pledge: network
debug1: client_input_global_request: rtype hostkeys-00@openssh.com want_reply 0
debug1: Remote: /opt/ssh/getkey %f:1: key options: agent-forwarding command permitopen port-forwarding pty user-rc x11-forwarding
debug1: Sending environment.
debug1: Sending env LANG = en_US.UTF-8
SSH-2.0-OpenSSH_7.6p1 Ubuntu-4ubuntu0.3
Protocol mismatch.
debug1: client_input_channel_req: channel 0 rtype exit-status reply 0
debug1: client_input_channel_req: channel 0 rtype eow@openssh.com reply 0
debug1: channel 0: free: client-session, nchannels 1
Connection to ssh.devcloud.intel.com closed.
Transferred: sent 3152, received 2704 bytes, in 12.3 seconds
Bytes per second: sent 255.4, received 219.1
debug1: Exit status 0
AthiraM_Intel
Could you please share the config file you are using?
Also check whether you are able to access JupyterLab.
paul24
cat ~/.ssh/config
# oneAPI DevCloud SSH config
Host devcloud
User u163970
IdentityFile ~/.ssh/devcloud-access-key-163970.txt
ProxyCommand ssh -T -i ~/.ssh/devcloud-access-key-163970.txt guest@ssh.devcloud.intel.com
Host devcloud.proxy
User u163970
Port 4022
ProxyCommand ssh -T devcloud-via-proxy
# If you must route outgoing SSH connection via a corporate proxy,
# replace PROXY_HOSTNAME and PORT below with the values provided by
# your network administrator.
Host devcloud-via-proxy
User guest
Hostname ssh.devcloud.intel.com
LocalForward 4022 c009:22
ProxyCommand nc -x PROXY_HOSTNAME:PORT %h %p
# DevCloud VSCode config
Host devcloud-vscode
UserKnownHostsFile /dev/null
StrictHostKeyChecking no
Hostname localhost
User u163970
Port 5022
# SSH Tunnel config
Host *.aidevcloud
User u163970
ProxyCommand ssh -T devcloud nc %h %p
LocalForward 5022 localhost:22
LocalForward 5901 localhost:5901
i will check JupyterLab
AthiraM_Intel
Could you please let us know whether you are able to access JupyterLab?
paul24
i am unable to use JupyterLab, it tells me
'DevCloud Enrollment is Required'.
if i click this i get
There is already an Intel DevCloud account associated with this email. Go to https://www.intel.com/content/www/us/en/developer/tools/devcloud/overview.html to access Intel DevCloud. For assistance resolving account issues, visit the Intel DevCloud Forum.
and im back where i started
AthiraM_Intel
Could you please check whether your account is expired or not?
To check the account expiration of your DevCloud account, please follow the below link :
https://community.intel.com/t5/Intel-DevCloud/DevCloud-Account-Expiration-How-to-check/m-p/1296418
If you face any issue, please let us know.
paul24
hi,
it was expired, the mess started with reactivation of the account.
thanks
AthiraM_Intel
We apologize for the inconvenience caused.
Can you try registering for Intel DevCloud for oneAPI using another email address and see if you are able to create a new account? If not, do get back to us.
Registration Link: https://devcloud.intel.com/oneapi/
AthiraM_Intel
We have not heard back from you. Could you please give us an update?
paul24
i created a new account as tarflah@posteo.de got devcloud user id u183069.
it authenticated
but then the problem is
     debug2: shell request accepted on channel 0
    Protocol mismatch.
and the connection is closed
niels
AthiraM_Intel
Could you please let us know whether you are able access JupyterLab?
Also share the screenshot of the error and the command you used.
niels1
hi,
access via JupyterLab works.
via ssh does not.
so probably there is all correct on your side.
thank you
AthiraM_Intel
Thank you for the update.
Could you please follow the below steps to connect to DevCloud via cygwin:
1. Download this simple Windows batch script install_cygwin.bat (highlighted in the screenshot) from below link: https://devcloud.intel.com/oneapi/documentation/connect-with-ssh-windows-cygwin/
2. Extract the downloaded script (keep it as default c:\cygwin64)
3. Now open the Cygwin64 terminal, which looks like below.
4. Now go to the below path and add the setup-devcloud-access-xxxxxx.txt to that path. (Connect with Cygwin | Intel® DevCloud)
path: C:\cygwin64\home\<User_name>
file: setup-devcloud-access-xxxxxx.txt
 5. Open the Cygwin terminal and follow the below commands.
ls
bash ./setup-devcloud-access-xxxxxx.txt
6. Connect to the DevCloud using( ssh devcloud)
ssh devcloud
If you face any further issue, please let us know.
niels1
hi,
i installed cygwin, following your instructions but its the same result:
u183069@devcloud: Permission denied (publickey)
niels
AthiraM_Intel
We are checking on this issue internally, will get back to you soon.
AthiraM_Intel
The issue could be that account keys are corrupted. Could you please create a new account.
If you gets a message that "account already exists", please let us know.
AthiraM_Intel
Glad to know that your issue is resolved. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel.
