Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1525 Discussions
unable to upload media files into devcloud samples code-Object detection
PKLim
unable to upload media files into devcloud samples code-Object Detection,
I try to upload the media files with no respond, when i try to rename it show Permission denied as below image capture.
ChithraJ_Intel
Hi Phoey,
Thanks for reaching out to us. Could you please give us answer to the below questions:
  1. Are you using oneAPI Devcloud or Devcloud for edge?
  2. Are you trying to rename a file in preinstalled sample? If that the case, you don't have permission to rename it.
Chithra
PKLim
HI Chithra,
I am using Devcloud for edge, I am try to upload customer video for the influence at object detection. it show access denial for upload a files or folder. but I am able to upload a video for other application like people counting. is there possible for us to upload customer video?
ChithraJ_Intel
Hi Phoey,
This forum is intended to handle only oneAPI Devcloud issues. Since you are working on Devcloud for edge, we are moving this query to Devcloud for edge forum for a faster response.
Chithra
Eltablawy__Alaa
Hello PKLim,
Thanks for reaching out.
To upload files to the IoT Devcloud, when you access Jupyter hub, click on the upload button on the top right corner of the page and upload your document.
Is that the procedure you followed to upload your file?
You can rename a file you created or uploaded or a file the lives in your home directory.
From the error message below, I believe you were trying to rename  /data/reference-sample-data/object-detection-python/cars_1900.mp4 to a different name, this will need permission.
Instead, you can rename the created link to cars_1900.mp4 in your home directory.
PKLim
HI Eltablawy,
Yes, that is the step i follow. but it didn't respond for an hour, when i try to rename its only pop up the error messages on access denial, when test for other sample, its allow for upload and rename.
