Intel® DevCloud
Help for those needing help starting or connecting to the Intel® DevCloud
1732 Discussions
walltime limited to max 00:20:00 with qsub
fcharras
Hi
I try to access a gpu node with qsub but I can't input a walltime more than "00:20:00" for an interactive session.
I need the gpu access to test software I'm experimenting interactively for a project at the intel CoE.
I need interactive access for longer time on gpu node, so I can easily synchronize code and scripts or type ipython commands, without going through the hassle of starting and setting the node up every time.
My co-worker @ogrisel seems to be able to input arbitrary walltimes. Could my account be upgraded too please ?
Thank you
fcharras
JesusE_Intel
Hi fcharras,
I've updated your account, your default Walltime should now be 1 hour and you should be able to set it to 8 hours max. Please give it a try and let me know if it works for you.
Jesus
VaradJ_Intel
Good day to you.
Could you please let us know whether you are using Intel DevCloud for oneAPI or Intel DevCloud for the Edge or Intel DevCloud for FPGA ?
Also, If you are using Intel DevCloud for oneAPI can you share the exact steps with which you are connecting to devcloud and the command you are using to get a gpu compute node on devcloud.
Thank You!
Varad
fcharras
I'm using Intel DevCloud for the Edge . I open a terminal in the jupyter web interface, than I use the command
pbsnodes
to look for nodes with a discrete GPU. and then
qsub -I -l nodes=some-node,walltime=05:00:00
so start an interactive session on the node (here, the session is limited to 5hrs)
But I can't register more than 20 minuts now, anything more than
qsub -I -l nodes=some-node,walltime=00:20:00
and qsub rejects the command.
JesusE_Intel
Hi fcharras,
Jesus
fcharras
It works thanks a lot @JesusE_Intel
JesusE_Intel
Great! If you need any additional information, please submit a new question as this thread will no longer be monitored.
