Intel® Developer Cloud
Help connecting to or getting started on Intel® Developer Cloud
162 Discussions
Login in Intel Developer Cloud instance
malshaye
I am trying to ssh my instance following the instructions in the dev cloud however, it asked me for guess password.
the issues is  like:
https://community.intel.com/t5/Intel-Developer-Cloud/Login-in-Intel-Developer-Cloud-instance-issue/m-p/1594185
however no solution was mentioned.
Dayang_Intel
Hi malshaye,
To ensure we can assist you effectively, please provide the following details. If not applicable, please use 'N/A'. We appreciate your cooperation, and we look forward to resolving this matter promptly.
1. Severity level for this case.
Low: General guidance
Medium: System impaired
High: System down
Critical: Business-critical system down
2. Instance Details of your Intel® Developer Cloud.
Instance Type:
Instance ID/Resource ID:
Start Time/Created:
Instance IP address:
The instance details can be found at https://console.cloud.intel.com/, in the Compute Instances section under My Instances. Click on your instance name in the "Instance Name" column to view instance type information. Please refer to the image below.
3. Is this your first time connecting to the instance?
4. Are you using corporate network (company/university WiFi) or non-corporate network (own/home WiFi)?
5. Is there any important data stored on the instance?
6. Can the IDC support team access the instance and perform the required operations to validate or fix an issue if needed?
7. Screenshot of the Preview Instances tab.
8. Screenshot of the Preview Keys tab.
9. Screenshot of your .ssh folder.
10. Screenshot of the WSL terminal when attempting devcloud as the password.
Dayang
Dayang_Intel
Hi malshaye,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Dayang
