I want to pull some images from docker hub for vector DB on IDC, which required docker installation.
Could you please suggest how I can use Docker ?
It's bit urgent for my POC
Hi Karry2,
You can install Docker in Intel® Developer Cloud instance with command below:
sudo apt install docker.io
Then, validate your Docker installation by pulling and running hello-world image:
sudo docker pull hello-world
sudo docker run hello-world
Peh
Hi Karry2,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Peh
