Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Conda update Conda fails
Richard_H_Intel1
ERROR conda.core.link:_execute_actions(339): An error occurred while installing package 'defaults::tqdm-4.32.1-py_0'.
CondaError: Cannot link a source that does not exist. C:\intelpython3\Scripts\conda.exe
Running `conda clean --packages` may resolve your problem.
Attempting to roll back.
conda clean --all --yes : does nothing
Quick googling showed this problem  was seen before when the install script removed conda, then tried to link tqdm, then tried conda install.  With this failing the link process.
Pretty new to python, so not sure how to hack install scripts any advice welcome.
More info:  This is off a fresh install of: w_pythoni3_p_2019.4.088
Richard_H_Intel1
Trial  and error fix:
conda install tqdm -f
conda update conda worked after that.
Womack__Brian
This has generally been broken in the last two releases (2019 Updates 4 and 5).
This used to work:
  1. Extract Intel Python distribution ZIP file to C:\IntelPython3
  2. In that directory, type setup_intel_python.bat
  3. Scripts\Activate
  4. conda update conda
  5. conda install pyodbc pymssql sqlalchemy seaborn ipython xlrd xlwt openpyxl
  6. conda install spyder jupyter
Now, it consistently dies on step 4, and the later steps do not work at all.  Intel, please fix this.
Paul_B_Intel1
My problem was solved by modifying this file:
C:\Users\pbusser\.condarc
proxy_servers:                                        <-- add if not there
  http: http://proxy-us.intel.com:911 ;        <-- add
  https: https://proxy-us.intel.com:912 ;    <-- add
channels:
  - intel
  - defaults
bay__sam
Just created an account to say thank you to this person for posting their solution, and also to confirm to others that it worked for me :)
Wei_W_Intel2
Yes, run "conda install tqdm -f" before running "conda update conda" , that did make fix the error.
Thanks Richard-Hardin!
