Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
452 Discussions
Need to download Python 3.8 (oneAPI 2021.4)
ActionPace
I see the 2022.1.0 Release for Python is available at the following link:
https://www.intel.com/content/www/us/en/developer/articles/tool/oneapi-standalone-components.html#python
Where a script can be downloaded for Linux
https://registrationcenter-download.intel.com/akdlm/irc_nas/18720/l_pythoni39_oneapi_p_2022.1.0.214.sh
I searched everywhere but I don't see how to get to download scripts for older releases.
According to the release notes at:
https://www.intel.com/content/www/us/en/developer/articles/release-notes/distribution-for-python-release-notes.html
To get Python 3.8 it appears I could try to get Intel® oneAPI 2021.4
But HOW do I get at the older install shell script for Linux?
Thanks for any advice!
RemyaP_Intel
The latest release for python supports only v3.9. To install previous version of Python, you will have to use conda.
Otherwise, to install an older version, you need a license serial number. You must purchase a license if you do not have one. Follow the below steps to learn more:
Please let us know if this resolves your issue.
Remya Premdas
RemyaP_Intel
For installation of python 3.8, please run the below command
Command : conda create -n idp intelpython3_core python=3.8
Note: Here python 3.8 version will get installed in the conda environment <idp>. It is recommended that you create a new conda environment for the installation by replacing idp with the new environment name in the above command
After installation, please make sure to activate the environment using the below command.
Command : source activate idp
For further reference please refer the below link.
https://www.intel.com/content/www/us/en/developer/articles/technical/using-intel-distribution-for-python-with-anaconda.html
Remya Premdas
RemyaP_Intel
We haven't heard back from you. Has your issue been resolved?
Remya Premdas
ActionPace
Thanks for your response.
I hadn't been planning to use conda (Anaconda or Miniconda) in my setups, since the original download (of 3.9) didn't require conda that I am aware of, but if it's the only way to do it, then that's what I can plan in my future builds.
David K
RemyaP_Intel
Remya Premdas
RemyaP_Intel
Thanks for accepting our solution. If you need any additional information, please post a new question as this thread will no longer be monitored by Intel
Remya Premdas
