Intel® Distribution for Python*
Engage in discussions with community peers related to Python* applications and core computational packages.
Packages in Conda are outdated
Oywa__Martin
I noticed that almost all python packages are outdated in conda, and I have to update them my self while using the notebooks. Is there a possibility where they just keep the packages updated for us?
AthiraM_Intel
Are you using intel channel to download the packages?
Also, could you please share few packages that you tried to install.
AthiraM_Intel
Could you please share the above mentioned details.
Oywa__Martin
Sorry for the late response. Yes I used the Intel channel to download.
I tried installing torchvision and torch, and after it did, I couldn't import torchvision because
the required version of PIL was 7.0 and Intel has 4.0.
AthiraM_Intel
We are forwarding this case to Engineering team.
Oywa__Martin
Ying_H_Intel
Hi Martin
This is Ying from Intel python support team. Thank you a lot for your reports. we also noticed the issues for a while.   It may be  because Intel python own one old validation matrix and release product . so  keep old one.  We released a new version 2020.1 recently. you are welcomed to try it.
We will try our best to keep the version with latest version.
Ying
Ying_H_Intel
Dear all,
We have new version 2020 update 2 release in conda  repo , where we update the package version. If possible, please try it and let us know if any issues.
https://anaconda.org/intel/repo
About the PIL and PyTorch problem here,  as intel contribute  pytorch by pyTorch channel directly.  so we just  use the PyTorch channel by default .   I suggest to use
>conda install pytorch torchvision cudatoolkit=10.2 -c pytorch
to install pytorch.
for example, i try today,
(base) yhu5@clx01:~/Desktop$ conda install pytorch torchvision cudatoolkit=10.2 -c pytorch
Collecting package metadata (current_repodata.json): done
Solving environment: done
## Package Plan ##
  environment location: /home/yhu5/intelpython3_2020/intelpython3
  added / updated specs:
    - cudatoolkit=10.2
    - pytorch
    - torchvision
The following packages will be downloaded:
    package                    |            build
    blas-1.0                   |              mkl           6 KB
    cudatoolkit-10.2.89        |       hfd86e86_1       365.1 MB
    libtiff-4.1.0              |       hc7e4089_6         668 KB
    libwebp-base-1.1.0         |       h516909a_3         845 KB
    ninja-1.10.0               |       hc9558a2_0         1.9 MB
    olefile-0.46               |             py_0          31 KB
    pillow-6.2.1               |   py37hd70f55b_1         632 KB
    pytorch-1.5.1              |py3.7_cuda10.2.89_cudnn7.6.5_0       424.3 MB  pytorch
    torchvision-0.6.1          |       py37_cu102        11.7 MB  pytorch
                                           Total:       805.2 MB
The following NEW packages will be INSTALLED:
  blas               anaconda/pkgs/free/linux-64::blas-1.0-mkl
  cudatoolkit        pkgs/main/linux-64::cudatoolkit-10.2.89-hfd86e86_1
  libtiff            anaconda/cloud/conda-forge/linux-64::libtiff-4.1.0-hc7e4089_6
  libwebp-base       anaconda/cloud/conda-forge/linux-64::libwebp-base-1.1.0-h516909a_3
  ninja              anaconda/cloud/conda-forge/linux-64::ninja-1.10.0-hc9558a2_0
  olefile            anaconda/cloud/conda-forge/noarch::olefile-0.46-py_0
  pillow             anaconda/cloud/conda-forge/linux-64::pillow-6.2.1-py37hd70f55b_1
  pytorch            pytorch/linux-64::pytorch-1.5.1-py3.7_cuda10.2.89_cudnn7.6.5_0
  torchvision        pytorch/linux-64::torchvision-0.6.1-py37_cu102
Proceed ([y]/n)?
and the deafult PIL is 6.2.1 version.  if the version is still low, maybe you can pip install direclty PIL 7.x version to workaround the issue.
Ying
