6562 Discussions
About ncDeviceOpen:799 Failed connection to device (1.7.2-ma2480) with error 5
I using the NCS1 is work, but i change the NCS2 is doesn't work.
Hi @bigfoottt
The Neural Compute SDK only supports the original Intel Movidius Neural Compute Stick. You will need to download and install the OpenVINO toolkit for the Intel Neural Compute Stick 2.
Take a look at the getting started guide for the NCS 2:
https://software.intel.com/en-us/articles/get-started-with-neural-compute-stick
Jesus
I faced same Error with Windows 10 OS.
I tried running my Myriad X (named UP AI CORE X) with the tutorial below.
but, at "Step 4. Test the installation", an error occured.
  • the device could be seen as Movidius Myriad X on device manager.
  • after the error occurd, the device can not be seen.
Best Regards.
I show a part of the Error
classification_sample.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\car.png" -m "C:\Users(myname)\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.xml" -d MYRIAD
[ INFO ] InferenceEngine:
API version ………… 1.6
Build ……………… 23224
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ] C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\car.png
[ INFO ] Loading plugin
API version ............ 1.6 Build .................. 23224 Description ....... myriadPlugin
[ INFO ] Loading network files:
C:\Users(myname)\Documents\Intel\OpenVINO\openvino_models\ir\FP16\classification\squeezenet\1.1\caffe\squeezenet1.1.bin
[ INFO ] Preparing input blobs
[ WARNING ] Image is resized from (787, 259) to (227, 227)
[ INFO ] Batch size is 1
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the plugin
[35mE: [ncAPI] [ 0] ncDeviceOpen:799 Failed connection to device (3.1-ma2480) with error 5[0m
Error
Hi @yamaken
Which version of the OpenVINO toolkit are you using? Which version of Visual Studio do you have installed? I don't have an AI Core X available to test right now, I will try to get a hold of one.
Try to install the latest OpenVINO toolkit version R1.1, it was just released a couple of days ago.
Jesus
Hi @Jesus_at_Intel
My OpenVINO toolkit version is "2018 R5.0.1 for Windows"
Thank you for your cooperation.
(Without "-d MYRIAD" option , there is no probrem to run samples.)
I will try and report the latest version of OpenVINO. wait a moment.
