6584 Discussions
Accuracy drop in dlstreamer yolov5 custom model
shekarneo
Hi was using yolov5m custom model trained on crowdhuman dataset.
i tried to convert the model IR format using utralytics export.py code and used detect.py there i got the good results.
The same i followed the dlstreamer guide (Yolov5 Model Preparation Example — Intel® Deep Learning Streamer (Intel® DL Streamer) documentation) to convert the model to IR format and used the below model_proc file there i got the multiple and improper bboxes compared to detect.py.
please find the below pipeline and model repo link
Using openvino 2022.3
Model repo: deepakcrk/yolov5-crowdhuman: Head and Person detection using yolov5. Detection from crowd. (github.com)
MODEL_PATH=../models/yolov5_head_openvino_model/FP32/yolov5m.xml
PROC_PATH=../models/yolov5_head_openvino_model/crowdhuman_yolov5.json
cmd="filesrc location=../videos/NVR_ch18.mp4 ! decodebin \
! videoconvert ! video/x-raw, format=BGR \
! queue ! gvadetect model=$MODEL_PATH model-proc=$PROC_PATH threshold=0.7 device=CPU \
! queue ! gvatrack \
! queue ! gvawatermark ! queue ! videoconvert ! fpsdisplaysink sync=false"
gst-launch-1.0 $cmd
model_proc:
    "json_schema_version": "2.2.0",
    "input_preproc": [
        "format": "image",
        "layer_name": "images",
        "params": {
                "resize": "aspect-ratio",
                "color_space": "BGR",
                "reverse_channels": true
    "output_postproc": [
            "converter": "yolo_v5",
            "output_sigmoid_activation": true,
            "do_cls_softmax": true,
            "iou_threshold": 0.20,
            "bbox_number_on_cell": 3,
            "cells_number": 20,
            "classes": 2,
            "labels": ["person", "head"],
            "anchors": [
                10.0,
                13.0,
                16.0,
                30.0,
                33.0,
                23.0,
                30.0,
                61.0,
                62.0,
                45.0,
                59.0,
                119.0,
                116.0,
                90.0,
                156.0,
                198.0,
                373.0,
                326.0
            "masks": [
                6,
                7,
                8,
                3,
                4,
                5,
                0,
                1,
                2
using yolov5 detect.py (IR format), removed person class
`detect.py.png`
Using dlstreamer pipeline
`dlstreamer.png`
Wan_Intel
Hi Shekarneo,
Referring to Line 14 output_postproc in your Model-proc File, could you please change "labels": ["person", "head"], to "labels": ["head"], in line 23, and see if the issue can be resolved?
Wan
shekarneo
Hi wan,
If i change the "labels": ["head"] the number of classes are 2 it gives me error.
0:00:02.774746148  1483 0x565550db46f0 WARN                 kmssink gstkmssink.c:1160:gst_kms_sink_start:<fps-display-video_sink-actual-sink-kms> error: Could not open DRM module (NULL)
0:00:02.774788742  1483 0x565550db46f0 WARN                 kmssink gstkmssink.c:1160:gst_kms_sink_start:<fps-display-video_sink-actual-sink-kms> error: reason: No such file or directory (2)
0:00:02.774823112  1483 0x565550db46f0 WARN                basesink gstbasesink.c:5881:gst_base_sink_change_state:<fps-display-video_sink-actual-sink-kms> error: Failed to start
0:00:02.822407738  1483 0x565550db46f0 WARN              ximagepool ximagepool.c:500:gst_x_image_sink_check_xshm_calls: MIT-SHM extension check failed at XShmAttach. Not using shared memory.
0:00:02.858997065  1483 0x565550db46f0 WARN              ximagepool ximagepool.c:500:gst_x_image_sink_check_xshm_calls: MIT-SHM extension check failed at XShmAttach. Not using shared memory.
0:00:02.875303764  1483 0x565550db46f0 WARN                 basesrc gstbasesrc.c:3693:gst_base_src_start_complete:<filesrc0> pad not activated yet
Pipeline is PREROLLING ...
0:00:02.898917888  1483 0x565550d3ab60 WARN                 qtdemux qtdemux.c:3244:qtdemux_parse_trex:<qtdemux0> failed to find fragment defaults for stream 1
Redistribute latency...
0:00:03.172265025  1483 0x565550d3a6a0 WARN                 default inference_impl.cpp:474:InferenceImpl:<gvadetect0> Loading model: device=CPU, path=../models/yolov5_head_openvino_model/FP32/yolov5m.xml
0:00:03.172340407  1483 0x565550d3a6a0 WARN                 default inference_impl.cpp:476:InferenceImpl:<gvadetect0> Initial settings batch_size=0, nireq=0
0:00:03.186059231  1483 0x565550d3a6a0 WARN                 default model_proc_parser_v2_1.h:50:parseProcessingItem: The 'layer_name' field has not been set. Its value will be defined as ANY
0:00:04.986374130  1483 0x565550d3a6a0 ERROR             GVA_common post_processor_c.cpp:22:createPostProcessor: Couldn't create post-processor:
Failed to create PostProcessorImpl
        Failed to create "yolo_v5" converter.
                Number of classes greater then number of labels.
0:00:04.986463484  1483 0x565550d3a6a0 WARN      gva_base_inference gva_base_inference.cpp:796:gva_base_inference_set_caps:<gvadetect0> error: base_inference based element initialization has been failed.
0:00:04.986509957  1483 0x565550d3a6a0 WARN      gva_base_inference gva_base_inference.cpp:796:gva_base_inference_set_caps:<gvadetect0> error:
post-processing is NULL.
ERROR: from element /GstPipeline:pipeline0/GstGvaDetect:gvadetect0: base_inference based element initialization has been failed.
Additional debug info:
/home/dlstreamer/dlstreamer/src/monolithic/gst/inference_elements/base/gva_base_inference.cpp(796): gva_base_inference_set_caps (): /GstPipeline:pipeline0/GstGvaDetect:gvadetect0:
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
0:00:04.987362338  1483 0x565550d3a6a0 WARN           basetransform gstbasetransform.c:1379:gst_base_transform_setcaps:<gvadetect0> FAILED to configure incaps video/x-raw, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)BGR and outcaps video/x-raw, width=(int)1280, height=(int)720, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)25/1, format=(string)BGR
0:00:04.989638122  1483 0x565550d3a860 WARN                GST_PADS gstpad.c:4361:gst_pad_peer_query:<videoconvert1:src> could not send sticky events
0:00:05.011254426  1483 0x565550d3a6a0 WARN      gva_base_inference gva_base_inference.cpp:946:gva_base_inference_transform_ip:<gvadetect0> error: base_inference failed on frame processing
0:00:05.011305041  1483 0x565550d3a6a0 WARN      gva_base_inference gva_base_inference.cpp:946:gva_base_inference_transform_ip:<gvadetect0> error:
Failed to submit images to inference
        Mapper is null
ERROR: from element /GstPipeline:pipeline0/GstGvaDetect:gvadetect0: base_inference failed on frame processing
/home/dlstreamer/dlstreamer/src/monolithic/gst/inference_elements/base/gva_base_inference.cpp(946): gva_base_inference_transform_ip (): /GstPipeline:pipeline0/GstGvaDetect:gvadetect0:
        Mapper is null
0:00:05.026946452  1483 0x565550d3ab60 WARN                 qtdemux qtdemux.c:6967:gst_qtdemux_loop:<qtdemux0> error: Internal data stream error.
0:00:05.026999576  1483 0x565550d3ab60 WARN                 qtdemux qtdemux.c:6967:gst_qtdemux_loop:<qtdemux0> error: streaming stopped, reason error (-5)
ERROR: from element /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0: Internal data stream error.
../gst/isomp4/qtdemux.c(6967): gst_qtdemux_loop (): /GstPipeline:pipeline0/GstDecodeBin:decodebin0/GstQTDemux:qtdemux0:
Freeing pipeline ...
Wan_Intel
Hi Shekarneo,
Thanks for the information.
Could you please change the classes to 1 and see if the issue persists?
Wan
shekarneo
Hi wan,
if i change classes to 1 i am getting error.
can you try to reproduce the issue from your side if possible?
        Mapper is null
        Mapper is null
0:00:03.052007273   151 0x557de98bbb60 WARN                 qtdemux qtdemux.c:6967:gst_qtdemux_loop:<qtdemux0> error: Internal data stream error.
0:00:03.052070496   151 0x557de98bbb60 WARN                 qtdemux qtdemux.c:6967:gst_qtdemux_loop:<qtdemux0> error: streaming stopped, reason error (-5)
Wan_Intel
Hi Shekarneo,
We'll further investigate the issue and we'll update you as soon as possible.
Wan
Wan_Intel
Hi Shekarneo,
Thanks for your patience.
I've run your PyTorch model with detect.py from the GitHub repository, and the inference result was good:
https://github.com/deepakcrk/yolov5-crowdhuman/tree/master
Inference Result of PyTorch model with detect.py:
Before converting your PyTorch model into Intermediate Representation, I've converted your PyTorch model into an ONNX model. Are you able to run the ONNX model with your detect.py? I would like to check the inference result of the ONNX model with your detect.py before we convert it into an Intermediate Representation.
Wan
shekarneo
Hi wan,
I am able to run detect.py using onnx model, Please find the below screen shot
python3 detect.py --weights crowdhuman_yolov5m.onnx --source data/images/bus.jpg --imgsz 640
Wan_Intel
Hi Shekarneo,
I ran the detect.py script with the command: python3.9 detect.py --weights crowdhuman_yolov5m.onnx --source data/images/bus.jpg --imgsz 640. However, I encountered the following error: detect.py: error: unrecognized arguments: --imgsz 640
Next, I ran the detect.py script without --imgsz 640, I encountered the following error: _pickle.UnpicklingError: invalid load key, '\x08'
Could you please share the ONNX model with us so we can replicate the issue on our end?
Wan
shekarneo
Hi wan,
Please find the exported onnx file link. 71mb is the maximum size so i uploaded to gdrive.
Wan_Intel
Hi Shekarneo,
Could you please run the inference with the sample video in the link below and share the result with us?
https://github.com/intel-iot-devkit/sample-videos/blob/master/people-detection.mp4
On the other hand, please share the environment details with us:
Host Operating System
Hardware specifications
Wan
Wan_Intel
Hi Shekarneo,
I also encountered an accuracy issue when running the object detection pipeline using YOLOv5m with Intel® Deep Learning Streamer Pipeline Framework Release 2023.0.
1. Object Detection using PyTorch model with detect.py
python3 detect.py --weights ../crowdhuman_yolov5m.pt --source ../people-detection.mp4 --device CPU
2. Object detection using Intermediate Representation with Intel® DL Streamer
gst-launch-1.0 filesrc location=people-detection.mp4 ! decodebin force-sw-decoders=true ! queue ! gvadetect model=crowdhuman_yolov5m.xml model-proc=yolo-v5.json inference_interval=1 threshold=0.4 device=CPU ! queue ! gvawatermark ! videoconvert ! autovideosink sync=false
    "input_preproc": [
            "format": "image",
            "params": {"resize": "aspect-ratio","color_space":"BGR"}
            "iou_threshold": 0.4,
            "classes": 2,
            "anchors": [
                10.0,
                13.0,
                16.0,
                30.0,
                33.0,
                23.0,
                30.0,
                61.0,
                62.0,
                45.0,
                59.0,
                119.0,
                116.0,
                90.0,
                156.0,
                198.0,
                373.0,
                326.0
            "masks": [
                6,
                7,
                8,
                3,
                4,
                5,
                0,
                1,
                2
Let me check with relevant team and I'll update you as soon as possible.
Wan
shekarneo
Hi Wan,
Thank you for the update.
I am running on macOS with an Intel chipset and using OpenVINO 2023.2. The YOLOv5m 80-class model from the Ultralytics repository works fine for me. However, when I use the 2-class model, it produces false results.
shekarneo
Wan_Intel
Hi Shekarneo,
Let me check with the relevant team and we'll update you at the earliest.
Wan
Wan_Intel
Hi Shekarneo,
Thanks for your patience. We've received feedback from relevant team.
Referring to Known Issues in Intel® Deep Learning Streamer Pipeline Framework Release 2023.0, we regret to inform you that intermittent accuracy fails with YOLOv5m and YOLOv5s is a known issue.
Our developers are working on resolving the issue. Please stay tune for the next Intel® Deep Learning Streamer Pipeline Framework Releases. Sorry for the inconvenience and thank you for your support.
Wan
shekarneo
Hi wan,
Thanks for the update, i did not face this issue with yolov5m pretrained models from ultralytics repo.
This issue i am facing only with the yolov5m custom trained models.
shekar
Wan_Intel
Hi Shekarneo,
Thanks for your information.
We encountered the same issue as you when running the object detection pipeline using your custom YOLOv5m model with Intel® Deep Learning Streamer Pipeline Framework Release 2023.0.
We will fix the issue in the future Intel® Deep Learning Streamer Pipeline Framework Releases. We are not sure when the fix will be available, but please stay tuned for the next release. Hope it helps.
Wan
Wan_Intel
Hi Shekarneo,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan
